CLICK HERE--><--CLICK HERE
Why tach from the front!
Started by Paul Taylor, February 25, 2026, 07:25:14 PM
Previous topic - Next topic
0 Members and 2 Guests are viewing this topic.
Paul Taylor
I see guys tach the motor from the front and reach over the prop to adjust the needle.
The RPM will read the same from behind and you don't have to reach around a meat slicer to adjust the needle.
Just saying 😳
My Therapy involves Balsa wood and bad decisions.                               https://www.wpmpa.com
Everyone becomes a memory. The question is: will you be a good one or a bad one?
Kindness echoes. So does cruelty. People remember both.
Crist Rigotti
With any piston engine you can download the app "enginerpm" to your I pad less expensively than any tach device.  It works from a safe distance, including the center of the circle.
Two stroke or four stroke, any number of cylinders.
For electric buy a real tach and don't try it with fluorescent lights.
