  • June 18, 2025, 10:02:26 AM
Author Topic: Equipment at WC  (Read 14316 times)
Offline graham webster
Equipment at WC
« on: November 11, 2016, 08:44:16 AM »
Hi All,
 Does anyone know the equipment ( model, engine, tank, pan, filling system) used by the top teams at the 2016 WC.
Offline Ian Thompson
Re: Equipment at WC
« Reply #1 on: August 16, 2017, 01:57:59 AM »
Hi , I have only just found this Forum.In the final. The 2 Australians used models made from Fitzgerald molds. Tanks & Engines were Lerners, No pans in modern F2C models way to heavy!! Engines are mounted on steel studs glued or molded into the fuselage crutch. Fuels systems have a main tank & a separate "cool fuel tank" with a metering valve to add this at a pit stop if required.Compression can be chemically added or reduced using this system. The cool fuel is normally some sort of Naptha with a higher flashpoint than the Kerosene in the fuel mix.
Not 100% sure but The French probably used Yugov engines & tanks in their Black Spirit models .
Hope this helps
Ian
Offline Peter Grabenstein
« Last Edit: November 15, 2017, 03:58:33 AM by Peter Grabenstein »
I hate pessimists, I prefer optimists.
Impossible is done immediately, miracles take longer.
I don't care who your father is ......... as long as I fly here,
Nobody walks, runs, floats or flies across my circle ......... not even to fetch fish, wine or bread.
