CLICK HERE--><--CLICK HERE
Jeti Spin ESC RPM Set Up
Started by Steve Dwyer, March 26, 2026, 02:14:45 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Steve Dwyer
For the Jeti Spin Pro 66 ESC where can I find the RPM adjustment chart curve showing the range of values and corresponding milliseconds?
Fred Underwood
#1
This may not be the answer that you are looking for.  You set the Max and Min rpms in the ESC.  Rogerio suggests numbers that happen to be 4000 rpm apart and the timer has 400 clicks.  A click is approximately 10 rpm.The middle of the Max and Min rpms onthe ESC should be at aboutthe middle of the adjustment, about 200 rpm.  Adjust up and down on the timer from there a need for lap time. Depending on prop, line length and other variables, you can adjust the Max and Min in the ESC up or down to adjust the rpm range on the clicks and stay torard the mid range of 200 on the timer.  Not usually necessary unless you are close th the Max or Min.
Sorry if that isn't clear, it has been a while since I tried to write it out.
Fred
352575
