  • July 16, 2025, 09:50:42 AM
Author Topic: Plettenberg 20-16, Phoenix ICE Lite 75  (Read 7188 times)
« on: May 29, 2013, 08:57:15 PM »
I finally got around to saving the file:
# Castle Link Data File
# Created: Wednesday, May 29, 2013
# Do Not Edit This File By Hand
Hex55: 85
Brake Delay: 1s
Brake Ramp: Fast
Cutoff Type: Soft Cutoff
Motor Start Power: 59
Direction: Forward (*)
Cutoff Voltage: Auto Li-Po (*)
Current Limiting: Normal (105A) (*)
Brake Strength: 100
PWM Rate: 8 Khz
Sample Frequency: 2 Sample / Sec
BEC Voltage: 5
Power-On Beep: Enabled (*)
Auto-Lipo Volts/Cell: 3.2 Volts/Cell (*)
Motor Timing: 2
Data Log Enabled: 255
Vehicle Type: Control Line
Throttle Type: Governor Mode
Throttle Response: 5
Governor Gain: 50
Initial Spool-Up Rate: 8
Head Speed Change Rate: 10
Auto Rotate Enabled: False
Governor Mode Type: Low
Vehicle Setup - Battery Type: LiPo
Vehicle Setup - Number of Cells: 5
Vehicle Setup - Battery Voltage: 18.5000
Vehicle Setup - Gear Ratio: 1.000
Vehicle Setup - Motor Kv: 720
Vehicle Setup - Motor Number of Poles: 10
Desired Head Speed 1: 3999
Desired Head Speed 2: 3999
Desired Head Speed 3: 3999
Castle Link version 3.52.9
« Last Edit: May 29, 2013, 09:16:57 PM by Howard Rush »
Re: Plettenberg 20-16, Phoenix ICE Lite 75
« Reply #1 on: May 29, 2013, 09:07:00 PM »
Here's the file:
