Here's what we have the ZTW factory set the default programming in the ESC's so that they work perfectly with the KR Governor.
1) Battery Type - Lipo
2) RPM - RPM OFF
3) Start – Start Accel ( the KR Governor has an automatic soft start so this is not needed on the ESC)
4) Brake - ON
5) Timing - Auto
6) Rotation - Reverse
7) Cut off Voltage – 3.2V
Cut off power – Reduce Power
