  • July 18, 2025, 01:50:14 AM
Author Topic: Jeti Spin programming  (Read 10393 times)
Online Igor Burger
« on: November 19, 2014, 09:33:29 AM »
Tania converted my text describing parameters for Jeti Spin ESCs as I use them to home page. I think it will be good to post the link also here.
http://www.maxbee.net/articles/spinprog.htm
Offline José Almeida
Re: Jeti Spin programming
« Reply #1 on: November 20, 2014, 06:02:51 AM »
Thanks Igor.  ;)
For those less familiar with the electrics, is an excellent base to starting!
This is the same for all Jeti Spin ESC or particulary for Jeti Spin 66?
Online Igor Burger
« Reply #2 on: November 20, 2014, 07:36:05 AM »
Yes, it is valid for all Spins and Spins opto. I use the same settings for indoors with Spin 11 (with different RPM). But not valid for Spint PRO and Spin PRO OPTO.
« Reply #3 on: November 25, 2014, 11:13:13 AM »
GreatPrimer. Maybe someone can pin it to the top so it doesn't get lost.
Reading through it seems the Jeti Spin has an active brake for stopping the prop rotation on shut down similar to the Castle ESP's, correct?
What is the max rpm that it can operate at in governor mode?
Best,     DennisT
Online Igor Burger
« Reply #4 on: November 25, 2014, 02:12:05 PM »
Yes Spin has brake, it is the only way for FAI F2B.
I do not think that governor has any RPM limitations, but ESC itself has I think 200 000 rpm for 2 pole motor, means up to 30 000 on 14 pole motor. But I am not sure.
