Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 31, 2025, 02:41:52 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Electric Stunt
ESC Settings
Initial spool up question
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Initial spool up question (Read 8007 times)
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
on:
September 09, 2015, 05:33:24 PM »
The default setting on my Phoenix Lite 75A for initial spool up rate was low (2). I tried it and it takes awhile to run up to rpm. Is it better to have it set to the high spool up rate (
. What is the up and down side?
Logged
Mark Scarborough
2015
Trade Count:
0
Admiral
Re: Initial spool up question
Reply #1 on:
September 09, 2015, 05:40:03 PM »
if the nose on yoru airplane is fragile,, it could rip it off with torque spool up,,
it also puts a higher amp load on the esc on fast,,
I run mine on one step below hi as i recall
Logged
Crist Rigotti
25 supporter
Trade Count:
0
Admiral
Electric - The future of Old Time Stunt
Reply #2 on:
September 09, 2015, 06:43:12 PM »
I take about 3 to 4 secs to get up to full RPM. Why risk a quick start and the extra wear on the system.
Logged
Igor Burger
Trade Count:
0
Admiral
Reply #3 on:
September 09, 2015, 09:20:19 PM »
I use Jeti Spin and it has setting directly in seconds, I found 3 to 4 seconds to be most confortable, especially on grass, I can react and I feel much safer on starts than with shorter times and far far better then when someone releases model at full power.
Logged
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Reply #4 on:
September 10, 2015, 12:21:01 PM »
Thanks. That kinda what I thought. I reset to (7). A click below high.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Electric Stunt
ESC Settings
