  • June 14, 2025, 06:15:06 PM
Author Topic: FM-9 Programmer  (Read 11564 times)
Offline Perry Rose
FM-9 Programmer
« on: February 08, 2022, 01:11:50 PM »
I have one that may need repair. Plugged into an FM-9 timer and it says to press OK to continue it doesn't continue. Any suggestions? I didn't buy it from Brodak.
Online Brent Williams
Re: FM-9 Programmer
« Reply #1 on: February 08, 2022, 01:29:24 PM »
Are you pressing the power button on the timer as you power on the Hubin programming box?
If it is having troubles, you can send it to Will Hubin for evaluation and an update to the most current chip.
Online Dave Rigotti
Re: FM-9 Programmer
« Reply #2 on: February 08, 2022, 01:48:36 PM »
Check the cable for intermittent connections......
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline Perry Rose
Re: FM-9 Programmer
« Reply #3 on: February 08, 2022, 02:02:03 PM »
It works. It didn't come with instructions and I didn't think of two buttons at the same time. Thanks for the help.
