  • July 17, 2025, 09:37:35 PM
Author Topic: E-Flite Power 25, 870 KV, Phoenix 50 Ice Lite  (Read 9091 times)
Offline Mike Haverly
« on: March 19, 2013, 08:15:57 PM »
I have no idea what happened to the original thread but the data was bogus anyway.  I did that on my laptop and I noticed that this time when I fixed things that the values didn't always stay the way I entered them, especially the pole count and the cell number.  It worked just fine and to this point it is a mystery.  Here are the real values.
Castle Link Data File
Created: Tuesday, March 19, 2013
Do Not Edit This File By Hand
Hex55: 85
Brake Delay: .6 sec (Delayed) (*)
Brake Ramp: Immediate (*)
Cutoff Type: Hard Cutoff (*)
Motor Start Power: 59
Direction: Reverse
Cutoff Voltage: Auto Li-Po (*)
Current Limiting: Insensitive (80A)
Brake Strength: 100
PWM Rate: Outrunner Mode
Sample Frequency: 1 Sample / Sec (*)
BEC Voltage: 5
Power-On Beep: Enabled (*)
Auto-Lipo Volts/Cell: 3.7 Volts/Cell
Motor Timing: 4
Data Log Enabled: 15
Vehicle Type: Control Line
Throttle Type: Governor Mode
Throttle Response: 5
Governor Gain: 49
Initial Spool-Up Rate: 5
Head Speed Change Rate: 15
Auto Rotate Enabled: False
Governor Mode Type: High
Vehicle Setup - Battery Type: LiPo
Vehicle Setup - Number of Cells: 5
Vehicle Setup - Battery Voltage: 18.50
Vehicle Setup - Gear Ratio: 1.0000
Vehicle Setup - Motor Kv: 870
Vehicle Setup - Motor Number of Poles: 14
Desired Head Speed 1: 13750
Desired Head Speed 2: 13800
Desired Head Speed 3: 13800
Online Howard Rush
Re: E-Flite Power 25, 870 KV, Phoenix 50 Ice Lite
« Reply #1 on: May 29, 2013, 09:03:04 PM »
omoshiroi desu
