  • July 31, 2025, 01:43:55 PM
Author Topic: Settings; CC Pheonix Edge 50 w/KR Timer  (Read 7220 times)
Offline Kevin Muckleroy
« on: January 01, 2019, 12:21:53 PM »
Settings; CC Phoenix Edge 50 w/KR Timer
Anyone got updated settings for Castle Phoenix Edge 50 (or Lite ver.)
Only Program settings I can find is for the Ice 50 Lite and what is shown can not be done with Castle Link
Vehicle Type: Airplane
Throttle Type: Fixed-Endpoints
Throttle Response: High (8)
The Follwing can not be programmed with "Vehicle Type: Airplane" Mode is selected as suggested
Governor Gain: Medium (25)
Initial Spool-Up Rate: Medium (5) (*)
Head Speed Change Rate: Medium (5) (*)
Auto Rotate Enabled: False
Governor Mode Type: Simple
Vehicle Setup - Battery Type: LiPo
Vehicle Setup - Number of Cells: 5
Vehicle Setup - Battery Voltage: 18.5000
Vehicle Setup - Gear Ratio: 1.000
Vehicle Setup - Motor Kv: 770
Vehicle Setup - Motor Number of Poles: 14
Desired Head Speed 1: Optional
Desired Head Speed 2: Optional
Desired Head Speed 3: Optional
Re: Settings; CC Pheonix Edge 50 w/KR Timer
« Reply #1 on: January 24, 2019, 11:27:39 PM »
I have three, a 50, 50 lite and 75 lite.  All have a "Control Line" type.    I use the Huben timers and "Airplane" type dosn't allow you to set the RPM's and the boost under load is missing.
« Reply #2 on: January 25, 2019, 01:58:21 AM »
The KR Timer sets RPM and Gain (boost) So I just need to program it for "Airplane" mode?
« Reply #3 on: January 25, 2019, 07:12:33 AM »
My experience with the 50 lite was that it ignored the timer RPM and especially the gain in the "airplane" mode.  It only used the timer RPM and gain in the "Control Line" type.  It also would not let you set many of the parameters to what we use.  I may not have all of this correct because I had no way to effectively measure the RPM on my trim flights using "Airplane" type (by mistake) so it may have been only the lack of gain that I observed.
I am rather new at this as well but I am attaching the settings for my standard 50 that I have used since last October.  They came from the settings I got from Norm Whittle's Cookbook when I converted.  FYI the time from start to full power is set too long. I intend to change that.
These may not be the optimal settings either but they work and any recommendations would be appreciated.  Castle link will let you upload these settings and you are welcome to do it.  That is how I got my first one to work.
Best of luck - Ken
