  • July 17, 2025, 05:02:50 PM
Author Topic: Cobra 2826/12 760Kv Phoenix 45 TP 5S 2700mah  (Read 15459 times)
Online Crist Rigotti
« on: March 15, 2013, 03:50:33 PM »
Here's mine for now.
Cobra 2826/12 760Kv
Phoenix 45
Thunderpower 5S 2700 ProLite G6
« Last Edit: March 17, 2013, 08:28:51 AM by Crist Rigotti »
Offline RC Storick
Re: Cobra 2826/12 760Kv Phoenix 45 TP 5S 2700mah
« Reply #1 on: March 16, 2013, 05:38:45 PM »
how do you save the file as a JPG?
« Reply #2 on: March 16, 2013, 06:24:39 PM »
Print it out on my printer, then scan it.  A bit of work.
Offline Jason Greer
« Reply #3 on: March 16, 2013, 10:24:08 PM »
A handy tool to have is pdfcreator.
http://www.pdfforge.org/pdfcreator
It's a free utility and once installed you will have a new printer named "PDFCreator".  When you go to print your document just select this printer and instead of printing to a physical printer,  you will be prompted to save the document as a pdf.
Jason
El Dorado, AR
AMA 518858
Offline Bob Hudak
« Reply #4 on: March 17, 2013, 08:27:59 AM »
Or use the free online converter- xps to jpeg.
« Last Edit: March 17, 2013, 08:50:12 AM by Bob Hudak »
350838
« Reply #5 on: March 17, 2013, 08:29:44 AM »
Jason it worked.  Thanks.
« Reply #6 on: March 17, 2013, 08:30:35 AM »
Just use the free online converter- xps to jpeg.
That would work too Bob.  Thanks.
