  • June 15, 2025, 03:45:39 AM
Author Topic: Initial spool up question  (Read 7648 times)
« on: September 09, 2015, 05:33:24 PM »
The default setting on my Phoenix Lite 75A for initial spool up rate was low (2). I tried it and it takes awhile to run up to rpm. Is it better to have it set to the high spool up rate (8). What is the up and down side?
Re: Initial spool up question
« Reply #1 on: September 09, 2015, 05:40:03 PM »
if the nose on yoru airplane is fragile,, it  could rip it off with torque spool up,,
it also puts a higher amp load on the esc on fast,,
I run mine on one step below hi as i recall
Offline Crist Rigotti
« Reply #2 on: September 09, 2015, 06:43:12 PM »
I take about 3 to 4 secs to get up to full RPM.  Why risk a quick start and the extra wear on the system.
Offline Igor Burger
« Reply #3 on: September 09, 2015, 09:20:19 PM »
I use Jeti Spin and it has setting directly in seconds, I found 3 to 4 seconds to be most confortable, especially on grass, I can react and I feel much safer on starts than with shorter times and far far better then when someone releases model at full power.
« Reply #4 on: September 10, 2015, 12:21:01 PM »
Thanks. That kinda what I thought. I reset to (7). A click below high.
