  • July 16, 2025, 09:49:57 AM
Author Topic: AXI 2826/12 Castle Phoenix ICE lite 75 A  (Read 15597 times)
Offline Peter Germann
« on: March 23, 2013, 04:54:17 AM »
Airplane (Derivate of Igor Burger's Max Bee)
Span: 61 in
Other dimensions: As per Max Bee
Wing area, including flaps: 693 insq:
Empennage (Crossfire Extreme) area, incl. elevators: 140 insq.
T/O weight: 65 oz/1'847 Gr.
Hardware
Motor: AXI 2826/12 with COOL1 fan
Propeller: APC 13 x 5.5 EP
Battery: TP G6 27005S PP 65C used to 73% of capacity
Timer: Hubin FM-9
ESC: Castle Phoenix ICE Lite 75 A
Flight setup
Lines: 0.015 x 64 ft eye-eye
RPM: 9’553
Speed: 5.35 sec/lap
ESC setup
Firmware: V 4.02
Vehicle Type: Control Line
Throttle Type: Governor Mode
Governor Mode: Governor High
Governor Gain: High (35)
Initial Spool-Up Rate: High
Head Speed Change Rate: Custom (20)
Battery Pack Voltage: 18.5 for 5S, see “Vehicle Setup Information”
Motor and Gearing: No Gearing/Direct Drive
kV of Motor: 760
Magnetic Poles in Motor: 14
Desired Head Speeds: left empty
Brake Strength: 100% (Hard)
Brake Delay: 0.3 sec
Brake Ramp: Medium
Cut-Off Voltage: 15.0 V active, for operation with anti-spark plug
Voltage Cutoff Type: Soft Cutoff
Auto-Lipo Volts/Cell: 3.0 Volts/cell active, for operation with anti-spark plug
Current Limiting: Very Sensitive (75A)
Current Cutoff Type: Soft Cutoff
Motor Start Power: Custom (66)
Motor Timing: Custom (3)
Direction: Reverse
PWM Rate: 8 Khz
Power-On Beep: Enabled
Link Live Enable: Disabled
BEC Voltage: 5.0 Volt
Logging: Enabled at 2 samples/sec for Battery Voltage / Battery Current / Controller Temperature / Controller Input Throttle / Motor RPM
CastleLink: V3.55.00
July 27 2013 PG
« Last Edit: July 27, 2013, 04:58:25 AM by Peter Germann »
Peter Germann
Online Crist Rigotti
Re: AXI 2826/12 Castle Phoenix ICE lite 75 A
« Reply #1 on: May 14, 2013, 09:01:50 PM »
Thank you Peter.  Very detailed.  Are you an Engineer?    :)
« Reply #2 on: May 15, 2013, 03:01:26 AM »
No, I am not, Crist. I did however have the privilege to head R&D staff for many years. This then brought with it a certain understanding for the need of accuracy...
Peter
Peter Germann
« Reply #3 on: May 15, 2013, 06:24:39 AM »
Peter
It shows.  Well done.
« Reply #4 on: May 15, 2013, 09:55:45 AM »
Peter
Completeness, too.
So, did it work?  How well?
« Reply #5 on: May 16, 2013, 09:35:17 AM »
Approx. 200 flights on two airplanes. All components work flawless, regardless of outside temp. No maintenance done. Motor bearings feel like being perfectly ok.
All ESC parameters seem to be correct, no problems whatsoever. Repeatability is close to be perfect, all temperatures remain well below limits.
Earlier used low cost 25C batteries did not reach more than 30 cycles and I have just recently switched to four well kown brand 65C types. So far approx. 20 cycles on ea. with voltage logs showing no indication of unusal drop and batteries remaining cool at approx. 35°C
Peter Germann
