Design => Engineering board => Topic started by: Jim Roselle on August 23, 2015, 05:22:35 PM
I need some help from someone who's better at mathematics than me.
Is there a formula I can use to increase the wing area of a model to a specific desired area? For example if I want to increase a models area from say 250 square inches to 350 square inches can I input both those values and come up with a multiplier for the span and chord that will give me the desired area?
I hope this question makes sense.
Jim
Divide 250 into 350 to get the ratio of areas, then take the square root to get the scaling factor.
350/250 = 1.4
sqrt(1.4) = 1.18 or 18% larger linear dimensions
Multiply all the linear dimensions (chord, span, etc) by 1.18 and your airplane will be 40% bigger in area.
Thank you!
