  • August 01, 2025, 09:17:10 AM
Author Topic: Let Me Be The First. Tethered Flight Math. & More  (Read 18408 times)
Offline Dick Fowler
« on: June 20, 2009, 10:01:05 AM »
I've find this link very informative...
http://www.mh-aerotools.de/airfoils/control_line_aero_1.htm
The whole site has some good information.
« Last Edit: June 25, 2009, 01:16:49 PM by Dick Fowler »
Dick Fowler AMA 144077
Kent, OH
Offline Archie Adamisin
Re: Let Me Be The First.
« Reply #1 on: June 22, 2009, 08:24:51 AM »
If you like that, try out the JAVA prop program.  Very neat and easy to use.
Archie Adamisin
Muncie, Indiana
Archie Adamisin
Burlington, KY
Alan Hahn
« Reply #2 on: June 22, 2009, 09:15:30 AM »
Another nice prop program (as well as an electric motor program). Look at the bottom of the page for a the prop program. What I like about this particular program is that you can fix a rpm and the look at power and torque needs as the flight speed varies.
http://www.drivecalc.de/
Another bonus is that there are both Windows, Mac, and Linux versions.
Here is a link to some calculations I did for various prop parameters (pitch, diameter, # blades...) which I originally posted in the Electric forum--where the real propeller heads lurk!
http://stunthanger.com/smf/index.php?topic=7574.0
« Reply #3 on: June 22, 2009, 11:40:46 PM »
    That's a very useful program - in fact, in about 30 seconds I proved the point that I spent about half a week and a dyno and thrust stand test trying to convince Leonard Neumann (i.e. 4" pitch has a steeper thrust/velocity curve and a lot more static thrust than 6" pitch, when set to the level flight speed.   I also discovered that my *really cheesy* prop simulation was pretty darn close and gave decent results/
« Reply #4 on: July 29, 2009, 07:42:40 PM »
Hi Brett
care to share the info about the thrust/velocity curves?
I would be interestes in seeing anything like that
Alan Hahn
Re: Let Me Be The First. Tethered Flight Math. & More
« Reply #5 on: July 30, 2009, 06:40:06 AM »
Well you could check out my link.
