  • August 01, 2025, 09:08:56 AM
Author Topic: Leadout Offset  (Read 6956 times)
Offline TomLaw
Leadout Offset
« on: July 07, 2012, 04:03:27 PM »
Bellcrank deflection versus leadout length change.
Inboard wing: 28"
Bellcrank: 4"
Leadout separation: .5"
Four degree max difference for this arrangement.
Offline Douglas Ames
Re: Leadout Offset
« Reply #1 on: July 08, 2012, 10:11:50 PM »
So if you trim neutral at the handle after finding optimum L/O offset, and assuming you keep your B/C at neutral, will this L/O angularity effect the elev. throw (up vs. dwn deg.) enough to matter?
AMA 656546
Re: Leadout Offset
« Reply #2 on: July 09, 2012, 02:21:11 AM »
Who knows what his definition of offset is?  Who cares what the bellcrank does?
This has been completely determined, with diagrams showing the parameters and their definitions.  What's the point in repeating it halfway?
Offline TomLaw
Re: Leadout Offset
« Reply #3 on: July 09, 2012, 02:31:25 PM »
Reinventing the wheel!
Re: Leadout Offset
« Reply #4 on: July 09, 2012, 04:04:00 PM »
Tom,
I don't know who you are, but I like your reply.
You're thinking, "out of the circle!"
That phrase, coined by Avaiojet.  ;D
I have plenty of interest in Bellcrank placement and I know a bit about it.  n~
Always room for conversation.
Charles
Re: Leadout Offset
« Reply #5 on: July 10, 2012, 08:03:51 AM »
Charles
really?
Offline TomLaw
Re: Leadout Offset
« Reply #6 on: July 10, 2012, 11:30:22 AM »
This could turn into a real 'circular argument'.
Online Trostle
Re: Leadout Offset
« Reply #7 on: July 10, 2012, 06:49:34 PM »
Charles
Tell us more, please! Particularly your knowledge about bellcrank position relative to the CG.
Offline TomLaw
Re: Leadout Offset
« Reply #8 on: July 10, 2012, 07:07:13 PM »
The bellcrank position relative to the cg is not in this model. I have only worked out the relative mechanical connections  and response of the entire control system. Not knowing the lift and drag coefficients of the various surfaces, and fuselage, as well as the  thrust of the propeller when flying 'yawed out' would be a real handicap to quantifying this behavior.
Re: Leadout Offset
« Reply #9 on: July 10, 2012, 08:28:55 PM »
   Is there an emoticon for putting my fingers to my temple and pulling the trigger?
Offline TomLaw
Re: Leadout Offset
« Reply #10 on: July 10, 2012, 09:08:18 PM »
I could tell you in a qualitative way, if it would make you feel better.
Re: Leadout Offset
« Reply #11 on: July 10, 2012, 10:04:05 PM »
   I wasn't responding to you, but to the post I quoted.
Offline TomLaw
Re: Leadout Offset
« Reply #12 on: July 10, 2012, 10:42:37 PM »
Too much is just enough!
Re: Leadout Offset
« Reply #13 on: July 11, 2012, 10:35:55 AM »
 HB~> HB~> HB~> HB~>
Sorry this is as close as we have...    HB~> HB~> HB~> HB~> HB~> HB~> HB~>
Offline TomLaw
Re: Leadout Offset
« Reply #14 on: July 11, 2012, 11:01:49 AM »
"Isn't it astonishing that all these secrets have been preserved for so many years just so we could discover them!" Orville Wright
