  • June 21, 2025, 05:02:10 AM
Author Topic: Reynolds number to use  (Read 3632 times)
steven yampolsky
« on: October 26, 2012, 11:17:23 PM »
I am running analysis in Profili and it's asking me about Reynolds numbers. Can anyone help me figure this out. I keep coming up with 500K as the number but in discussions in this section I keep seeing 1000K as the number. Which one is it?
I used the following calculator: http://aero.stanford.edu/StdAtm.html
I  used 80ft/sec speed which is equivalent 55mph which is equivalent to 5.2 second laps with 63 ft lines.
I left 1ft for the chord and tried smaller numbers with little change
I used 1000ft MSL as the altitude.
The calculator gave me 496742.40
Am I doing something wrong or is 500K the right number?
Re: Reynolds number to use
« Reply #1 on: October 27, 2012, 10:57:12 AM »
I get 500K.  I'm using the wing chord as the characteristic length, which I believe is correct.  I'd like to hear from the folks that actually know what they're doing (I don't count) as to whether that's right.
The equation is (density) * (length) * (velocity) / (viscosity).  So it should have a 1:1 correlation with length -- if it doesn't, they've got an error in there.
« Reply #2 on: October 28, 2012, 04:02:56 PM »
I sent you both a Reynolds number calculator.
« Reply #3 on: October 28, 2012, 04:27:28 PM »
That was a long way of saying "Yup, about 500K", Howard.
I do love 'merican units.
Although "slugs per cubic foot" seems more an apt way to measure gardens in Seattle vs. Wichita, rather than a measure of air density.
steven yampolsky
« Reply #4 on: October 28, 2012, 08:38:11 PM »
That's a cool spreadsheet Howard! Thank you! Man, I wish forum owner has enabled spreadsheets as attachments! We could build a library of cool spreadhseets!
Offline Chuck_Smith
« Reply #5 on: October 29, 2012, 08:28:13 AM »
Don't forget to adjust your results for 3-d flow, or you'll be off on the area calculation.
AMA 76478
Offline Chuck_Smith
« Reply #6 on: October 29, 2012, 08:29:10 AM »
Aspect ratio will affect the lift vs AoA curve for the aircraft.
AMA 76478
