  • July 11, 2025, 09:55:47 PM
Author Topic: Yet another Ro-Jett 65 question  (Read 1639 times)
« on: September 13, 2007, 08:52:21 PM »
OK, Richard uses 5-40 bolts to attach the header. I notice that the bolts are just long enough to grab 4 or 5 threads. Maybe 5/8" long. The hole is maybe 3/8" deep down to the liner. Any reason I can't use a bolt just a little longer so it grabs a few more threads?
Offline Wayne J. Buran
Re: Yet another Ro-Jett 65 question
« Reply #1 on: September 13, 2007, 09:05:33 PM »
Why?
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
« Reply #2 on: September 14, 2007, 02:08:14 PM »
Wayne,
See, now you asked a question and I have to give an embarrassing answer. I'd hoped no one would ask.
I overtorqued one of the screws and stripped out the last couple of threads. The choices seem to be go to a longer screw (3/4" versus the 5/8" long that comes with the engine), tap out the hole to a larger size (surprisingly, I have some 6-48 screws that would work - even have a tap), or send the engine back to Richard to be repaired. I'd hoped that just using a longer screw would work OK. It's only the last 2 or 3 threads.
Hmm, maybe a helicoil?
sigh.... Now the cat's out of the bag. HB~>
« Reply #3 on: September 16, 2007, 05:22:56 PM »
Ok, I'll go ahead and just tap it out 6-40. that should do for it. Just got a tap and the screws in the mail.
« Reply #4 on: September 16, 2007, 05:36:19 PM »
I would suggest a Heli-Coil. Who knows what you will run into with a longer SHCS.
Wayne
Wayne Buran
Medina, Ohio
AMA 14986 CD
« Reply #5 on: September 16, 2007, 05:56:06 PM »
Hi Randy,
If you have more depth in the hole, use the longer bolt.  You can put a Heli Coil in later if a longer bolt doesn't work.
« Reply #6 on: September 17, 2007, 10:41:01 AM »
Bill,
I was just concerned that the screws were the length they were for a reason. I didn't want to distort the case or something.
steven yampolsky
« Reply #7 on: September 17, 2007, 08:09:17 PM »
No worries, after the few threads of aluminum up frond, the majority of thread is actually inside 1/4 diameter yellow hard metal bolts that hold the top of the case and crankcase together.
« Reply #8 on: September 18, 2007, 07:37:17 AM »
Bill,
Hi Randy,
I can understand that. ;D  As we all know, the full strength of a bolt is already achieved at the length which equals the diameter of the bolt.  So a shorter bolt is as *Strong* as a longer bolt.  There should be no problem as long as you run both bolts the same length.
Offline captcurt
« Reply #9 on: September 18, 2007, 08:51:12 AM »
Oh Bill:
That's in a perfect world where the thread size is optimum for the material and the material is as strong as the screw!!  Unless that is some super alloy, neither is the case here!
Curt
« Reply #10 on: September 18, 2007, 09:42:17 AM »
Oh Bill:
Curt
Hi Curt,
What are you saying here?  As far as the *strength* of the *bolt*, itself, I have always been told by machinists, engine builders, and all, that the maximum strength of the bolt is reached at that point.
I was not referring to the strength of the joint that is created.
Have I been misinformed all these years? (this even goes into racing engines when I was doing that. ??? )
Online RandySmith
« Reply #11 on: September 18, 2007, 09:46:51 AM »
HI Bill
I think he is referring to the bolt going into aluminum,  that makes it not nearly as strong as the bolt, A 4-40 going into AL. threads  the depth of the width of the bolt will strip very  easy.
« Reply #12 on: September 18, 2007, 09:50:18 AM »
Thanks, Randy.   After I read it a few times, I believe you are right.  Curt is talking about the strength of the *bolted joint*.
I was just referring to the tensile strength of the bolt, itself, not the joint created by it.  ???
