  • June 16, 2025, 04:32:28 AM
Author Topic: Xoar props question  (Read 4874 times)
Offline Jim Nohsey
Xoar props question
« on: December 07, 2014, 09:00:55 AM »
Hey was just wondering if anyone has used these on cl planes?? Have used them on 120ax, 50 and 100 cc planes.
Jim Nohsey
Offline Akihiro Danjo
Re: Xoar props question
« Reply #1 on: December 07, 2014, 11:23:53 AM »
I have been using Xoar props, PJA 9 to 11 inch and PJG 7 and 8 inch, and satisfied with them. PJG 9 inch has too thick blades.
There are some other brands that MAY be manufactured by the same company, but Xoar brand is the best with respect to the QC.
Aki
« Last Edit: December 08, 2014, 12:55:15 AM by Akihiro Danjo »
« Reply #2 on: December 07, 2014, 05:27:49 PM »
Several have reported the wood 12-4 to work well on the OS .46LA-S. I haven't, but would, if I was flying a .46LA.
RSM props are made by Xoar for Eric Rule. The "10-6" is really about 10-5.5, and is considered a #1 choice for Fox .35 Stunts.
Some have reported that the 11-6 is real good on a .46LA. I think the 12-5.5 might be good on a ST G.51. Eric told me at a VSC that his props were a statistical average of the old TF paddle blade and the Rev-Up. Not sure if it was the "W" or "EW" Rev-Up, however.   H^^ Steve
« Reply #3 on: December 07, 2014, 08:11:37 PM »
I have been using the Xoar 13x6 repitched to 13x6.5 on my Saito .56 powered Score..  It's my favorite prop on that set up, and I've tried MAS and a few Eather 2 & 3-blades on it.
Xoar PJN
« Last Edit: December 09, 2014, 10:00:35 AM by Joe Yau »
« Reply #4 on: December 07, 2014, 11:28:34 PM »
please make sure we are all talking about the same Xoar ,, they make many varieties,,
Offline Michael Massey
« Reply #5 on: December 09, 2014, 12:39:03 AM »
I have been using Xoar props for over a year now.  They are all (that I use) the PJA series.  I have used 13x6 and 13x5 on Evo 60's and 11x5 and 12x4 on LA46's.
I like the props a lot.  They look great and they are balanced right out of the package.  The engines run great with them and they seem to be fairly consistent prop to prop.
Give them a try, I think you will be pleased witht he performance.
Eagle Point, Oregon
AMA 914713
« Reply #6 on: December 10, 2014, 12:19:31 AM »
Thanks, Brian!  ;)  ;)  ;)  ;)  ;) Steve
« Reply #7 on: December 10, 2014, 01:03:18 AM »
Xoar PJN
I cannot recommend you to use PJN electric props on 4st.
Aki
« Reply #8 on: December 10, 2014, 08:03:47 AM »
Aki
As why I didn't mention which Xoar I used in the original post.  I have used PJA as well.  Either way.. the quality are outstanding on these props.
Offline Chris Belcher
« Reply #9 on: December 10, 2014, 11:31:26 AM »
I have ben using these for over a year now and have bought at least 10 and only one was not pretty close to perfect balance (both hub and blade) and within at least a 1/4" of stated pitch. I use the PJA series. I like to use High RPM/low pitch set up..11-4   12-4 etc...great props and take to re-working well. A 12-4 on a LA46 at aobut 9,800- 10,000 RPM is pretty darn good. The only prop I found that worked better on my set up was a Brian Eather 11.5 x 5.5 repitched to 4.25..and it was better but not by much...but enough ;)
Offline SteveMoon
    • www.ultrahobbyproducts.com
« Reply #10 on: December 10, 2014, 02:35:14 PM »
I have been using a 14 x 6 Xoar prop on my Discovery Retro 76
and am really satisfied with the results. High quality, well made
props. I've also got one of the Xoar electric series props; 10 x 5,
on my electric Gieseke Nobler. Performs very well.
