  • June 14, 2025, 10:40:13 AM
Author Topic: Winter Engine Storage  (Read 2476 times)
Offline Dennis Saydak
« on: August 25, 2016, 12:28:16 PM »
Good Engines are expensive, especially for us northern guys because of the currency exchange factor. How should engines be treated for long term /over the winter storage. I'm particularly concerned about protecting the crankshaft bearings to prevent corrosion. I know some of the older 4 cycle engines suffered from rusted bearings especially during prolonged storage periods.
Offline Bootlegger
Re: Winter Engine Storage
« Reply #1 on: August 25, 2016, 01:42:03 PM »
 I have always used Marvel air tool oil, in plain bearing as well as ball bearing engines. I was told by an engine mfg that any oil that will burn is a good after run and storage oil.
 Also Rislone motor oil is good.
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #2 on: August 25, 2016, 02:25:25 PM »
If I want to store an engine long term I first run it to get it up to temp then I run it for about 5 sec on a mix of 5% synthetic oil 95% methanol then I mix 75% naptha 25% transmission fluid (or your favorite oil) and run 3 good primes off. This flushes out all the castor and leaves everything inside coated with preservative oil. I let the exhaust fumes air out then put it in a ziploc sandwich bag. Good for about 4 years.
Online RandySmith
« Reply #3 on: August 25, 2016, 02:45:45 PM »
DO NOT   use Risolene, Marvel Mystery, Auto Trans Fluid  etc.. These can cause many problems with some motors, they can swell or destroy seals  ans O Rings, Kill some plastics, and they do not protect as well as proper  After run oils.
Good quality after run oil is easy to get; don’t skip this step.  If you can’t find a good after run at your local hobby shop, there are many available that are made by several companies…then try Prather’s.  They make a good one and so does RJL , Marvel and Aero Products.  Do not use motor oil, Marvel Mystery oil; this is not after run oil.
Marvel makes excellent oil that can be used and as an after run oil and it is available from most auto parts stores and is called Marvel Air Tool oil.  As a matter of fact, most air tool oils can be used as an after run oil; they are designed to fight corrosion in metal air tools and this is exactly what we are looking for.  Another good place to get these types of oils are the large home supply stores like Home Depots and Builders Square type stores.  Look in the department where they carry air compressor and paint guns.  There are many brands of these oils so you see you have no excuse not to use them.
If you want long term storage first flush the engine out with Methanol or WD 40, others use Naptha, the put 5 to 8 drops in the intake, flip over a dozen or so times, repeat, the put several drops in the exhaust, flip over a few times, plug the intake and exhaust with paper towel plugs. the wrap in a dry or oiled cloth, put into zip lock baggie
« Reply #4 on: August 25, 2016, 07:25:50 PM »
Giving it a good shake , so it gets to the wrist pin wouldnt hurt .
Unoiled s/h injuns , its often the wrist pin that corrodes firstest .
Online RandySmith
« Reply #5 on: August 26, 2016, 01:10:06 AM »
I let it sit so the oil goes  to the bottom end, then put the piston up on top center  and hold the head  down, wait a min, the oil will  run into the  piston pin area, the just rotate  back n forth a few times
Offline Russell
  • ACE
« Reply #6 on: August 26, 2016, 05:08:02 AM »
I use pure ATF for storage and fill the crankcase and rotate the engine by hand along with turning it upside down to coat wrist pin area, then drain excess back out the venturi. While rotating some of the oil should move up into combustion chamber taking care of that and piston/cylinder walls. 10 and 20 years later no rust and no seal damage. ATF is made for seals and rust prevention. Take it from a transmission builder not that you ever have to be one to know or even an engineer.
You know what ATF is and it's inexpensive always available. After-run oil isn't "special" it's just a repackaging of something already on the market like ATF. Wait...could after-run oil be atf??
In the case of four-stroke engines I use it for an after run oil and fill the crankcase and drain.
John Leidle
« Reply #7 on: August 26, 2016, 10:20:23 AM »
   One of the last oils I'd use is Rislone,,,  did that , regreted it.   How bout some Whale Oil ?
    P. S.  I use air tool oil now
             because it removes any mystery.
« Reply #8 on: August 26, 2016, 10:37:28 AM »
   Indeed, but only Minke whale oil.  Where to they get off,  anyway, swimming around like they own the ocean? Pisses me off, I tell you.
Offline Fredvon4
  • Central Texas
« Reply #9 on: August 26, 2016, 11:37:53 AM »
NOT all ATF is a good idea...MOST are Ok to use.
BAD/not so good ATF...generic power steering or auto tyranny oil does have great After Run Oil qualities....BUT beware there are several blends with friction modifiers for the new skool lock up torque converters...these blends are some what abrasive....still usable, but I suspect should be 100% flushed out before running
My preferred is Marvel AIR TOOL OIL...cheap... and it is designed exactly for what we need...inert to most rubber/plastic blends, a lubricant, and hydrophobic...hydroscopic?...well... anyway does not attract or absorb water
Why I prefer Marvel Air Tool Oil
Decades ago, as a mechanic I invested a bit of cash for quality air tools: die grinders, ratchets, impact wrenches, nailers, sanders etc....... I was not set up with auto oilers and thought a spritz of WD40 when using would be OK...WRONG....with long disuse the tool would squeal, and be FUBAR...on disassembly I saw aluminum body to steel part corrosion and rust
I pitched a fit with the manufacture and got a nice gentleman who explained what AIR TOLL is supposed to do...including preserving tools that are used seasonally or infrequently...of course he was hawking his brand, but admitted most all ATO were pretty much same formula.
I got the Marvel Air Tool Oil  at Napa 3 or 4 decades ago. I have some of these tools that sat as much as 15 years without use... not cleaned, not in baggies, just in the bottom of a tool chest drawer ... the prof is a 70,000 to 90,000 RPM die grinder that is as good today as when I bought it from Sears in 1985...only ever fed ATO...and not ATF, 30W, or WD40 or any other lube ( I briefly had used spray white lithium grease)...very bad MoJo...do not use that stuff for any fast rotating parts....door hinges yes...
Fred von Gortler IV
« Reply #10 on: August 26, 2016, 12:20:46 PM »
Thanks for all the information guys but today I met someone for lunch who gave me the real scoop. He looked like a muscle builder and had a spinach sandwich for lunch. He said there's nothing better than Olive Oil.  y1 y1 LL~ LL~
John Leidle
« Reply #11 on: August 28, 2016, 10:26:34 AM »
    The remark about Whale Oil came from way back in High School ,  one of my teachers liked the fact I had a motorcycle & an interest in machinery. He talked about useing Whale Oil several times to me I really never understood his thoughts untill last Winter when Ron Howard brought out a movie about a Whaleing Ship.. I looked up some uses of Whale Oil & saw they put it in ATF  as a friction modifier...
                 Sick joke , John
« Reply #12 on: August 28, 2016, 11:26:51 AM »
Instead of any pre-storage run on some complicated fuel mix, I just use some Air Tool oil that came from Harbor Freight.  Some of my planes with engines have been resting in my storage room for several years, and they fire right up, after a healthy dose of ordinary glo fuel.
