Engine basics => Engine set up tips => Topic started by: frank mccune on November 07, 2015, 10:27:41 AM
Hello All:
Now that Mr. Frank Bowman has retired and stopped making piston rings, where may I have rings made for my model airplane engines? Did somebody take over his business?
Tia,
Frank McCune
what engine do u have
Hi Bob:
I was procrastinating about resurrecting some old McCoy .19 and .29 engines back to their former glory. I have some old "new" McCoy engine, rear intake Sportsman?, engines that I was hoping to get running just for old times sake. I think that these engines dated about 1948-49. I would really enjoy hearing them run. Placed in a period correct OTS plane, they would be that cat's pajamas!
I have had some of these engines that are "new" but the rings are so poorly fitted, I can not get the engines to run. A McCoy .098 really broke my heart as a youth!
Take care,
Frank McCune
Hi Frank, contact Frank Bowman! He has a reputation for making the best after market rings. I am pretty sure he is in the Vendor's Corner. He often goes by "chips a lot".
the .098 broke a lot of hearts and almost one co. i made a ring for my S/T 46 that worked fine , and am now making one for my S/T 60 ,will see how it go's
Bill Little ==The first post says Frank has retired? \ Which is true.? Has he retired or are you correct? Inquiring minds need to know. HB~>
Got a lathe and a torch? http://modelenginenews.org/techniques/piston_rings.html (http://modelenginenews.org/techniques/piston_rings.html)
It's true...Frank had retired from making rings. :(
