  • July 11, 2025, 03:32:28 PM
Author Topic: White coat on plug element!  (Read 1000 times)
Offline Larry Renger
« on: March 08, 2019, 07:31:46 PM »
I have had problems with the plug elements turning white, resulting in lousy engine runs.
What causes this, and how do you avoid it/and or better yet, cure it?
Re: White coat on plug element!
« Reply #1 on: March 08, 2019, 07:48:06 PM »
   What brand of fuel is it? These might be the dreaded "taters" that Brett has mentioned several times in the past. he has seen them accumulate when using SIG fuel. I use SIG fuel and have never experienced them, but I don't run piped engines. When this has been discussed, I have wondered if this was a phenomenon related to using a tuned pipe. But I doubt that you are flying a piped engine, knowing you from your posts over the years. Gotta be something in the fuel or being ingested by the engine when running.
« Reply #2 on: March 09, 2019, 12:30:27 AM »
    The "taters" are usually smooth blobs of a hard tan-colored substance, with a carbon coat, making them black. Scrape them and you usually see what looks to be melted plastic.
    Turning "white" is something else. I do occasionally see "frosted"-looking elements on other engines, and under a microscope you can see that the wire itself is eroding, causing it to be light gray and matte finish.
    Off-hand, I don't know the cause or cure, but its been around a long time. I have Tee Dee glow heads not run since the 60's that look like this.
