  • July 13, 2025, 12:29:32 AM
Author Topic: Which Fox .25 is this?  (Read 3967 times)
Offline Terry Caron
« on: July 10, 2015, 05:36:01 PM »
I had to buy a new tach and also found this at my L(R/C)HS.
I can't find any info on this baffled, plain bearing version - note shiny head, even shinier backplate and no exhaust baffle.
When was this produced?
Any good for stunt?
If so, is there a replacement nva that'll fit in place of the dual-needle assembly?
Thanks.
Terry
Add: further searching found a post saying the c/l version also said ".25 R/C" on the case - maybe it's early c/l with the r/c carb installed?
« Last Edit: July 10, 2015, 06:48:03 PM by Terry Caron »
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
Offline Terry Caron
Re: Which Fox .25 is this?
« Reply #1 on: July 10, 2015, 07:38:39 PM »
A closer look through AMEE and the c/l engine does say 25 R/C on the case, so this must be the c/l version converted to r/c (rats!!).
So, a useable stunt engine?
Terry
AMA 249824
NRA Life Member
Offline Gerald Arana
« Reply #2 on: July 10, 2015, 07:43:53 PM »
Near as I can tell by my "Andersen's Engine Bible" it's a 1972 version. But, was unavailable until '73. Also it was based on the 19 case and was supposed to be an economical (cheap) engine...........According to AEB.
Good luck, Jerry
Offline Terry Caron
« Reply #3 on: July 10, 2015, 07:53:55 PM »
Hi Jerry -
Yes, as shown in pic #2 above, it has vertical tapped holes at the exhaust stack.
Many posts by R/C'ers give very positive remarks about it, but they have quite different run requirements from c/l fliers.
Terry
AMA 249824
NRA Life Member
« Reply #4 on: July 10, 2015, 09:04:00 PM »
Bleedy Foxes .
Fudge . The BLACK prop washer likely means its a 80 odd , The Porting on these was livened up compared to the old ratshit alloy driver ones.
SEEING We Ashed . !  >:D
My 19s I set the head clearance at 6 or 7 thou. for twins , and mixnmatch with the 25's . 9 x 4 props or narrow blade 10 x 4s ( Gorrie Mi T )
or za zinger 9 x 5s on the 25s paired .
The Later 25 seems moe likeable / rortier .
thems scepter flight site ripoffs , might be the early 25s & 19s there too .
15 or 20 % Nitro gives them a wake up call . can be a bit feeble on 5 % , or stright Methanol - Castor .  LL~ LL~ LL~
The Fox Needles a bit of a joke. but works. Six or Seven turns Out. ( the control line one ) .
The LINER is UNHARDENED so good oil , 23% or mores a good idea .
ugly little mufflers dont slowem down a lot ( 35 Muffler Fit ) .
« Reply #5 on: July 10, 2015, 09:07:48 PM »
And Yea they can work well , with a ' break ' , if your after one . Say a 30 Oz plane . or 36 maybe . Then Theres NITRO , so No Problem .
( Nitro is TOURQUE ) . ( and double the consumption .  ;D >:( )
« Reply #6 on: July 10, 2015, 09:18:43 PM »
HYMPH .Scepter dont have the TESTS for the 72 odd version . Peter Chin , was in Aeromuddler And the U.S. Mags
Offline Terry Caron
« Reply #7 on: July 10, 2015, 09:21:43 PM »
Thanks Matt.
Mine's earlier (no muffler ears), I think the first version.
And the black prop driver is a spare .35 - the one on it looked more like your pic but was worn and won't grip the shaft lugs.
Terry
AMA 249824
NRA Life Member
« Reply #8 on: July 10, 2015, 09:50:42 PM »
HoKay . the R.C.s had a bar though the Ex Stack . hole F & R . . if not its not
Offline Terry Caron
« Reply #9 on: July 10, 2015, 09:59:34 PM »
No holes so I'm pretty sure it's the '72 c/l version w/a carb.
Terry
AMA 249824
NRA Life Member
Online Steve Helmick
« Reply #10 on: July 12, 2015, 02:07:27 PM »
It looks to be already run (some dirt on it)? Do you now own it?
This Fox .25 would not be a bad sport engine...Flite Streak, Veco Warrior, Ringmaster, etc. Fox should be able to sell you a CL venturi for it...avoid buying the NV assy if possible, and put in a Randy Smith NV Assy, ST, or ST Clone, in that order of preference. It should run a 2-2-2 type of run on something like the APC 9.5 x 4.5...not a LHS stock item, but it should be a prop worth trying.
If you use appropriate fuel (25%+ oil, mostly or all castor), it should outlast several McCoy readheads. Fox always seemed to use meehanite  cast iron for the pistons and leadloy for the cylinders on all of their lapped piston engines, so metallurgy is pretty much the same as a .35 Stunt. As with most Fox engines, vibration may be "noticeable"!
 H^^  Steve
Offline Terry Caron
« Reply #11 on: July 12, 2015, 03:42:09 PM »
Hi Steve - yeah, he offered it at a low price and when I countered with an even lower price, darned if he didn't take it!
It's been run but there's no dirt, just a bit of discoloration.
I haven't checked with Fox - I've read several posts saying they don't have any sort of parts now.
The carb on it is a strange design compared to modern ones and I may just try a remote setup on it.
I have 9-4 & 9-5 props, could cut down a 10-4, and I always run at least 25% oil, mostly castor, in these old engines.
Terry
AMA 249824
NRA Life Member
« Reply #12 on: July 12, 2015, 04:01:12 PM »
Hi Terry,
That .25 is the engine we used on my son Aaron's first "big" plane.  It was a TF kit Flite Streak.  It flew it really well and ran good for us when we set it just above a 4 cycle.  Kinda a real wet 2! LOL!!  I did have to buy two new crank cases for it.  Two crashes, two broken cases and all over grass.  All the cases had "R/C" on them and ours came with a venturi.  Still have the engine and would use it again for something along the lines of the Flite Streak.  Ran Fox Superfuel in it, but can't remember the exact prop.  I think we used a BY-O 10-5  (which was more like a 4 1/2).  Not sure. 58' eye to eye .015 and about a 4.9-5.0 lap time.  He got through all the maneuvers and inverted with that plane and we still have it!
BIG Bear
RNMM/AMM
Offline Terry Caron
« Reply #13 on: July 12, 2015, 04:35:58 PM »
Hi Bill -
Thanks for the memories.  :)
I appreciate hearing of others' experiences.
Terry
AMA 249824
NRA Life Member
