  • June 16, 2025, 02:05:14 AM
Author Topic: Super Tigre G20/.19 engine ????  (Read 1709 times)
Offline frank mccune
« on: August 17, 2021, 09:22:32 AM »
         Hi All:
         Does this engine have spi?
         Does it have a baffle on top of the piston?
         How many ball bearings does it have?
        Tia,
        Frank McCune
Online Massimo Rimoldi
Re: Super Tigre G20/.19 engine ????
« Reply #1 on: August 17, 2021, 11:28:57 AM »
 Hi.
The G20/19 (like many other S.T.) has undergone many changes over the years.  The first edition had the head made of casting, the piston had a baffle and two rings, the shaft was supported by a rear ball bearing and a front plane bushing.  The various modifications resulted in an engine with a machined head, a flat piston without a ring and two ball bearings.  I have no information regarding S.P.I.  but I would not rule it out especially in the first versions, the big brother G20/23 originally had two small open corners at the base of the exhaust port with the piston at the TDC.
Massimo
« Reply #2 on: August 19, 2021, 07:36:54 AM »
     Hello Massimo:
     Thank you for taking the time to reply.
     I have never owned a G20/.19 but my friend flies one.  Of course it is a very fine running engine!
     I have run many G20/.23 engines and they run very well if one omits a muffler! With a muffler and spi, the power is reduced about.40 percent!  They are a fun sport engine.
     Stay well,
     Frank McCune
« Reply #3 on: September 02, 2021, 05:48:24 PM »
Back in about 1949, I owned a Super Tigre G-19.  It was .29 cuin with a sand-cast crankcase.  It's main feature was an exhaust stack on each side.  I think it had ball bearings, but not sure.  I believe it was intended as a racing engine, although I used it for free flight with a 10 inch prop.  So it never got overr 9K RPM.
It was just another engine to me, and I later sold it for next to nothing.  I now realize my mistake!
