Hey Frank:
Prognostication is always iffy, but I think that IC engines are going to be around for a while, just not in as great of numbers. The 46LA is gone because from the RC'ers perspective it's a gutless wonder -- it was designed to be easy to handle and inexpensive, but as electrics got cheap enough it was simply overtaken. The 46AX has almost twice the power of a 46LA, makes more money for OS, and will probably be around for a while.
If you're going to fly a 40-sized RC plane you need a special place to do it, whether it's IC or electric powered. I think this is going to keep the space open for slimers, at least for the time being.
