Engine basics => Engine set up tips => Topic started by: frank mccune on March 04, 2020, 03:17:55 PM
Title: What is or was Castro’s MSSR? Was it a synthetic oil?
Post by: frank mccune on March 04, 2020, 03:17:55 PM
         Hello:
         I read the owner’s manual for a HP .40 engine and it recommend this oil at 20 % and No castor oil for lubrication.  What was this product?
        Tia,
        Frank
Title: Re: What is or was Castro’s MSSR? Was it a synthetic oil?
Post by: Dave Hull on March 04, 2020, 05:37:01 PM
Frank,
I think that was a full-synthetic oil that had limited distribution and is now discontinued. Nothing magical. I may be wrong.
Post by: Brian Hampton on March 04, 2020, 06:06:54 PM
Leaving aside jokes about cigars :) I believe Castrol MSSR was a synthetic gear oil which was used quite a lot in England and Europe.
Post by: Reptoid on March 04, 2020, 06:22:13 PM
Correct....It was/is a full synthetic gear oil used by some in New Zealand and Europe for model engines. No personal experience as I've never seen it in the US. For some reason Castrol chose not to actively market "Model Engine" oils in the US but were heavily involved in Europe. 99% of the synthetic oils used for "model engine" two strokes in the US were/are manufactured by Dupont/Dow Corning with some formulated for private labeled companies and generally only sold direct in Large quantities (think multiple drums). Motul markets "Micro 2T" in the US as well as Europe but it's pretty pricy and contrary to popular belief (and their marketing hype about all their other oils) is not Ester based. Primarily because pure Ester based synthetics don't mix well with Methanol
Post by: RandySmith on March 05, 2020, 12:57:35 PM
         Hello:
        Tia,
        Frank
Frank  you will  get excellent service  out of  just using something like  KLOTZ  Super Techniplate
Post by: richardm on March 05, 2020, 01:50:40 PM
From sunny New Zealand
Castrol MSSR suddenly became very popular for a short time, easy clean up and well priced compared to castor, my memory of it was my worn old motors (poor junior modeler)  quickly became more worn as the synthetic removed the varnish from the castor.
It fell out of favor, I use castor minimum 10% in every thing now
Post by: Massimo Rimoldi on March 05, 2020, 02:00:02 PM
Casrtol MSSR was the first synthetic oil available in Europe in the late 1960s. Probably due to the lack of adequate additives and perhaps due to incorrect use (it was often used without castor oil in steel cylinder engines) soon  it was abandoned after many engines were ruined.
Massimo
Post by: doug campbell on March 06, 2020, 07:40:52 PM
You are very lucky it wasn't sold in the USA. It was used during the castor oil shortage in the 70s. Many good motors were wrecked as it broke down rather easily
