Saturday I crashed a plane with a RO-Jett 65 in it. Hit right on the spinner (a glancing blow). It seemed the stud screwed into the crank shaft was out of round slightly (no other damage). Bearing seemed find and it spun freely. I went to a local screw and bolt supplier to see if I could get another screw in stud (it's actually considered a really long set screw). Pretty standard 1/4-28 thread. But it is 2" long. They didn't carry it (thanks Tacoma Screw) and couldn't order it. Guy told me there was no such thing. I showed him the original and he said it must be custom made unit.
So, I went to McMaster Carr's online site and what do you know? They not only carried it, but I had my choice of type of metal, end type and pitch. I ordered a box (only way you could get them) of 10. A big $5.71. So next time a local supplier tells you something like this, and such things have happened to me a number of times with local suppliers, just go to an actual supplier that carries more than the most very common stuff. And don't listen to them when they tell you there ain't no such animal.
