  • June 20, 2025, 08:15:48 PM
Author Topic: i dont get it ? lol  (Read 1164 times)
Offline steve pagano
i dont get it ? lol
« on: February 24, 2007, 07:16:54 PM »
Okay I've been flying about three and a half years now and my main competition plane is an impact with a s.t. 51 from tower hobbies (stock). I was wondering is there a difference in power or performance between same size engines? For example what's the difference between a s.t. 51, a ro-jett 51 and a p.a.51 since they're all 51 sized engines?
The reason i ask is mainly because when i find some thing that intrests me i want to learn every thing about it or i go crazzzzyyyy!lol n~ n~ n~
all replies appreciated
              thanks
« Last Edit: February 24, 2007, 07:53:48 PM by steve pagano »
Success isn't a destination.It's a journey!!!!!
A.M.A. 820-823
Online RC Storick
Re: i don't get it ? lol
« Reply #1 on: February 25, 2007, 05:26:01 AM »
In a word YES. Let me put it to you this way. An engine is just a air pump and the more air you can pump the more power you will put out. This is where volumetric efficiency comes into play. Port timing,combustion chamber shape,squish band angle and size. So the longer you keep the ports open the more air you stuff into the cylinder, more air means larger fuel charge= BIGGER BANG!!! = MO----POWER
Re: i dont get it ? lol
« Reply #2 on: February 25, 2007, 10:03:20 AM »
Hi Steve,
Since I have run both a ST G51 and the PA 51 in competition for several years, I can say that the PA 51 has more "stunt grunt".  The ST G51 is an outstanding engine, but the PA shows a good bit more when flying.  I have not dug into the "whys and wherefores", but it's stronger.  No Experience with a Ro-Jett 51, but in the other "sizes", the PA and Ro Jett put out more power than a comparable baffle piston engine.
I know it has to do with the things Robert wrote about.  Timing, head shape, etc., but I just put all that in the same category as the old auto engines.  Back in the early '60s you could get "several" versions of the Chevy 327 engine.  All  with a single four barrel carb that ranged from about 225 HP to 375 HP.  Heads, valves, intakes, carb, cam, etc., were progressively changed.  Power went up, fuel milage went down.  Now, smaller engines can put out the same or more HP with even better designs in the parts.  Same "size", way different power, and better milage...................
Bill <><
« Reply #3 on: February 25, 2007, 10:29:42 AM »
I don't have or run either of these engines, but I think part of the power increase comes from the way they are run. Higher RPM and less pitch. One thing I have noticed is the difference in sound between the old baffled engines and the newer ones without baffles. The newer ones without baffles running high RPM do not sound any faster or as fast as the old baffle jobs running less RPM. At least to my ears.
« Reply #4 on: February 25, 2007, 03:03:42 PM »
Hi Jim,
I would tend to agree on the rpm thingy, but there isn't a lot of difference in launch rpm between the two as I have run them.. and prop pitch has been within 1/2" pitch.  My ST G51 (T&L) in my USA-1 ran a 3 blade 11-3/4 X 4 1/2 prop and the PA in my Geo Juno usually runs a 12.2 X 4.2 2 blade.  Both in about the same weight airframe.  The ST ran the good old 4-2 while the PA runs almost dead 4 cycle.   I will be building a new USA-1 to use the PA 51 in with a header muffler.
They are just different animals. ;D
Bill <><
