  • June 21, 2025, 09:36:24 PM
Author Topic: cox medallion .049  (Read 851 times)
Offline bob werle
cox medallion .049
« on: July 15, 2008, 09:11:19 AM »
Does the spraybar in the medallion press out or is it threaded?  I have a medallion w/out the spratbar and I also have a plastic venturi assembly with the n/v and spraybar.  I thought it would be easier to just replace the n/v,spraybat than the whole venturi assembly.
ama 5871
Offline L0U CRANE
Re: cox medallion .049
« Reply #1 on: July 15, 2008, 11:25:23 AM »
Bob,
ASIR, it pushes in from the fuel nipple side. There's a shoulder where the fuel nipple meets the red palstic, correct? the needle/threaded side is smaller diameter than the knurl next to the shoulder.
If you push in a new spraybar, remember to check where the fuel jet hole or holes wind up. There's been discussion about this, probably in this topic somewhare...
Luck!
\BEST\LOU
Offline bob werle
« Reply #2 on: July 15, 2008, 04:50:11 PM »
thank you thats what I needed
ama 5871
Offline bob werle
« Reply #3 on: August 12, 2008, 10:37:51 PM »
I tried to push it out from the opposite side to the fuel nipple and found out there is a snap ring holding the spraybar in place It doesn't just press out.  The snap ring has to be removed first then it just slides out.,
ama 5871
