  • July 17, 2025, 07:05:18 PM
Author Topic: What's the thread size of the pressure tap nipples on OS mufflers?  (Read 2069 times)
I need to tap a tongue muffler to screw in a nipple taken from an OS-762 muffler. I expect they're all the same. Does anyone know what the thread size on those pressure nipples is? Hopefully the LHS will sell a tap that size.
The Tongue muffler is so thin I could just force it, but I'd prefer to thread it.
Rusty
Re: What's the thread size of the pressure tap nipples on OS mufflers?
« Reply #1 on: August 15, 2015, 12:26:59 AM »
I think it's 3mm -- do you have calipers?
« Reply #2 on: August 15, 2015, 01:15:41 AM »
Yes, SAE. I can do the conversion for the diameter. Still don't know the thread pitch. I'll see if a 3mm muffler bolt screws into the hole..
Offline Akihiro Danjo
« Reply #3 on: August 15, 2015, 02:06:59 AM »
I think it would be D 3.5mm and P 0.6mm.
Aki
« Reply #4 on: August 15, 2015, 09:57:45 AM »
Now that I'm actually in the same building as my mufflers I measured one -- M3x0.6.
« Reply #5 on: August 15, 2015, 09:57:34 PM »
Okay, thanks. Problem solved.
Rusty
