  • June 20, 2025, 10:21:14 AM
Author Topic: What's the problem with.....  (Read 2034 times)
Offline Terry Bolin
  • Havin' the time of our lives!
« on: December 27, 2006, 09:29:22 AM »
 ::) What's the problem/draw back with using a RC OS engine  that you already have instead of buying a CL version?
Thanks, Terry
Re: What's the problem with.....
« Reply #1 on: December 27, 2006, 10:01:08 AM »
Thanks, Terry
Hi Terry,
The OS LA, FP, "35 S",etc., are the same except for the carb/venturi.  A lot of people just wire the carb open and use the R/C engine.  Tming wasn't changed for either one.
Online RandySmith
« Reply #2 on: December 27, 2006, 10:18:38 AM »
Thanks, Terry
Hi Terry
The CL and  RC versions are  NOT all the  same, some of the CL versions have 2 port sleeves and some of the RC version do not.
Also you will want to put the NVA in the front and at least you will get a  venturie you can use buying a CL version over a  RC version.
I NEVER liked the way they run wired open, unless they were run in a 2 cycle mode, that being said If you care to you can you can  covert your  engine over to a CL version
« Reply #3 on: December 27, 2006, 12:57:50 PM »
Hi Terry
Sorry, Randy, I was not aware of that (2 port vis a vis 3 port)!  Is this with all the OS engines??  The 35 S, FPS and LAs I have had apart did not exhibit this, maybe I was just "lucky" ( ??? )
Bill <><
Offline Terry Bolin
« Reply #4 on: December 27, 2006, 01:29:02 PM »
 ::) Also with that being said, Do the OS Control line engines 4-2 cycle too?
Great site!
Terry
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #5 on: December 27, 2006, 04:06:04 PM »
Terry you need to tell us which OS engines you are asking about.
Offline Terry Bolin
« Reply #6 on: December 27, 2006, 08:20:58 PM »
Sorry, I have only seen the os-la versions. That is also what our local hobby shop stocks. So I that is what I would most likely use.
Thank you all!
Terry
Online RandySmith
« Reply #7 on: December 27, 2006, 08:28:01 PM »
Thank you all!
Terry
Hi Terry
The OS  LA s  are the ones  that come in 2 and  3 port versions, So if you buy a motor, I would suggest buying the Cl Version To Start with
Offline Dick Fowler
« Reply #8 on: December 28, 2006, 06:15:47 AM »
Hi Randy, from what I can see on the OS Max website and looking at some of my engines, the piston and sleeve part numbers are the same for either the C/L or RC versions of both the LA .40 and .46.
Here are the website pages for the LA .46 in both versions
C/L version  http://www.gpmd.com/cgi-bin/wgpprt100p?&I=OSMG1446
RC Version  http://www.gpmd.com/cgi-bin/wgpprt100p?&I=OSMG0046
I understand that the earlier versions of these engines were coming through with both configurations but they have settled on the two port sleeves.
So if it's a new engine either should be OK. If it's an ebay special... all bets are off.
Dick Fowler AMA 144077
Kent, OH
Online RandySmith
« Reply #9 on: December 28, 2006, 09:57:57 AM »
Hi Dick
Maybe so maybe no.   I have  2  "new"  OS 40 LAs here Rc versions that have  3 port sleeves
Depends on when and were they where bought I would imagine. OS  runs  1000s of these at one  time, and you can possibly get an engine that has parts that were ran several years  ago.
I have also had customers  ship me  OS  LAs  that are  new in box  with the old  3  port sleeve.
So I would still  suggest if anyone is buying one to get a  CL version, At least  you will have  a  venturie that is  usable.
Offline Terry Bolin
« Reply #10 on: December 28, 2006, 01:30:33 PM »
 :P Do the Os engine 4-2 cycle like a Fox engine?
Thanks for looking!
Terry
Online RandySmith
« Reply #11 on: December 28, 2006, 05:33:55 PM »
Thanks for looking!
Terry
Hi Terry
Yes many people run them in a  4-2  , however they do not sound like a FOX 35.
