  • July 31, 2025, 06:15:22 PM
Author Topic: More Engine setup tips or 9 steps...  (Read 65393 times)
« on: June 26, 2012, 03:56:00 PM »
ENGINE SETUP TIPS
  I have been asked many times lately to explain how to setup an engine for a good “stunt run”.  All to often I see motors running backwards from the ideal. Four stroking up hill and breaking into a 2 stroke downhill, going blubbery rich on insides, screaming lean on outsides, etc, etc.
  I would like to talk about the basics for setting up your engine to get a better machine. Someone once said a good stunt ship is 40% design 60% motor.
In a nutshell:
  Remember the needle is for setting the fuel mixture, not for setting the plane speed.
The prop pitch is for setting the speed of the airplane.
The prop diameter is for loading the engine properly and getting maximum thrust from the motor.
  Nitro is for controlling how much or how little break you have, this is to say how strong the motor will come on in the maneuvers. The other 2 items that work with this are :
 Compression and  venturie  size. This is not all there is to getting perfect engine runs. Many things work in conjunction with each other to achieving this goal, and most everything I am going to mention affects the others to some degree or another
The 8 basics to helping yourself to a better engine setup are:
1. Engine: Pay careful attention to matching the engine to the airframe, Don’t overpower or under power your plane, make sure your power plant is an acceptable weight for the ship it in and matches well with it, there is room to go bigger or smaller but remember engine weight and power.
2. Correct Fuel: Fuel is one of the most important things in tuning an engine, You must make sure that you have the correct oil type and percentage for the engine your using, example Fox 35s, OS 35s, Older McCoy’s and such need high oil content fuels 24to29% is common percentages. Half castor is good in these type engines as long as percentage is right.
Modern ABC and AAC engines will use much lower oil, 18 to 22 % percentages are the norm here. Nitro percentage is also key to getting the best from your power plant, There are so many ways to run stunt engines it is impossible to print anything but guide lines.
 I have written many times about fuel, you can get a copy of my Care and feeding of a stunt engine from the PAMPA archives, or on Stunt Hangar.
Typical Stunt engines   will use 5% nitro in cold weather going to 10 or even 15% in hot months, You can get in trouble using, say 15% in January, this setup would need 25% or more to be the equivalent in August. So unless you really have this working it is best to setup your engine for lower nitro in cold months and higher nitro in hot months, this will help keeps the run constant thru out the year. Also it will help control power in your motor.
3 .Correct Props: Props are also critical for achieving good engine runs; a prop needs to “load” the motor correctly without over or under loading the motor. It also needs to be the correct size and pitch to pull the airplane. This is an over simplication, but generally the diameter will be what you use to “load” the engine and the pitch will be what you pick to set the plane speed
Some things you will run into when over propping an engine are, Hard to set the needle on the ground, The engine will unload a lot and go rich in the air, The engine will run hot, or not cycle very rapidly.
When under propping generally you will notice the engine will also not cycle correctly, They at times will just 4 stroke thru everything, sometimes going into a 2 cycle at weird times.
A properly loaded engine will use a prop that if running a 4-2 break, will come onto a 2 stroke a 10 O’clock and back to a 4 at 2 O’clock. There are variations on this, you can have a strong motor just beep 2 stroke at the tops of maneuvers, but you shouldn’t have one that 4 strokes uphill and switches to a 2 stroke on the downhill parts of maneuvers.
4. Needle setting: Don’t try to use the needle to set the speed of the airplane; the needle is for setting the fuel-air ratio that goes into the engine. Typical settings are so the motor will be in a very fast 4 stroke when in level flight. If you set the needle to rich it will delay the engine switching and make the engine come on late in the maneuvers. If you set it too lean, you can sometimes run the risk of too much 2 stroke and going sagging lean in the tops of maneuvers, killing your drive and over heating the engine. Once you get this set , you will have  a little lead way in tweaking the needle in or out for conditions.
5. Airspeed: Most all planes like to fly at the airspeed they work best in, even exact or what is supposed to be the exact same design , will a lot of times want to fly at different lap times.  Example I have flown many SV-11s, at the same weight that fly at different speeds. Try to find the optimum speed for the plane your flying. This will depend a lot on the weight of the plane and also the power of the engines
6. Compression: Setting the correct compression for you motor isn’t a simple thing and will vary with nitro and prop size. Try to set the compression so when your engine hits into a 2 stroke it doesn’t come on too hard or too soft, This will work in conjunction with nitro and venturie size. Generally you will use higher compression for low nitro and  lower the compression when using higher nitro fuels.
7. Venturie : Venturie size is one of the keys to get a proper switching 4-2, while not coming on too hard or too soft or too late or too early. If you are constantly accelerating too much when your engine cycles you may need to go down on venturi size. If you are not cycling much or have too soft of a break or a late break , you may need to open the venturi up a size or 2. This will work in direct relationship to nitro and compression.
8. Fuel Tanks: A large portion of engine problem I see are really not engine problems, They are fuel delivery problems that many times relate to fuel tanks, Tanks are maybe the most critical component of your power train. Make sure you have a solid mount, and a tank with no leaks or cracks in the tubing, inside or out. I see many engines either speeding or slowing lap times at parts of the flight, this can many times be a cracked tubing inside the tank, particularly on uniflow tanks.When in doubt I suggest trying a new tank, if there is a difference, you may have bad tank. Don’t forget to use a good filter and make sure there are no holes in the fuel tubing. It is also advisable to try to keep the tank as close to the engine as possible.
9.  Plugs  can also be  a  major cause of trouble, and poor runs.  When you first crank the plane, notice if it goes rich and sags slightly when the battery is removed; if so, the plug is normally too cold.  This is  critical to getting a proper Stunt run. You could say the heat range of the glow plugs sets the "timing" on the engine, A hotter plug also need a hot plug to keep the engine run clean , a cold plug will allow the engine to stumble and burp , and even shut off if your running a deep 4 cycle.
Most plugs are designed to provide a  colder range than we want in C\L aerobatic engines , and you should try to get the right range for the motor. This range is almost always a "HOT" range, Many days of testing and much time and expense buying almost every plug on the market has yielded these results ;Thunder Bolt R\C long, T Bolt #3 , T Bolt 4 stroke, Glo Devil RC #300 long, Merlin, and the McCoy 59  , Enya 3 & 4, Fireball RC long, the Hobby Shack RC long, SIC RC long  a few of the OS hotter plugs and some of the FOX long and  Miracle plugs are best plugs for our use.  In almost all instances, use a long plus, as they will be substantially hotter than the shorts, plus they are deeper in the combustion chamber and this tends to keep things hotter and keeps  the plug elements cleaner, thus keeping the run cleaner.
A lot of times the plug problems show up as rich inside maneuvers and leaner outsides; this happens because gravity and centrifugal force ,forces the oil-fuel charge down on the element on insides, thus cooling the coil and pulls it away on the outside maneuvers, letting it naturally go leaner.  I have seen this problem instantly cured by simply changing plugs. Please  do not be  afraid  to put in a  new  glo plug , or try different types of plugs
These are just basic suggestion to help you tune your engine, and by no means covers it all. There are literally thousands of engine setups that would take volumes to cover, But I hope you can use this as a basic guide to helping get a better engine run.
Randy Smith
« Last Edit: March 22, 2015, 10:58:41 AM by RandySmith »
Re: More Engine setup tips or 8 steps...
« Reply #1 on: June 26, 2012, 06:19:43 PM »
On compression, can you expect that it'll always get a harder break on less compression, or more, or do you have to fiddle with it to find the optimum?
« Reply #2 on: June 26, 2012, 07:18:43 PM »
  More compression = harder break in most cases. Like anything you have to fiddle.
« Reply #3 on: June 26, 2012, 07:31:20 PM »
Hi Tim
Brett has it right it will normally break less but harder when it does, when using higher compression
Higher compression breaks less often and harder when it does break
Lowering the compression will normally make the engine break much more often and it will break softer. matter of fact if you lower the compression a lot, the engine can actually break into a 2 cycle and slow down, instead of having a little power increase.
Offline L0U CRANE
« Reply #4 on: June 26, 2012, 09:44:26 PM »
Given: I have little recent practice to support this, and that I am humbly offering a thought to highly current and active, excellent fliers...
The tank "height" location is a key trim factor in getting the same response going both ways, at low g, and in high g turns.
Regardless whether suction, muffler, low-case or high case pressure, or to less extent, bladder fuel feed, the relationship of the fuel jet in the choke to the mass center of the fuel WILL make a difference. The higher the available pressure on the fuel, the less difference, of course...
If we get all the other elements so well described in this thread nailed as well as may be, a wrong tank 'relative height' can still cause baffling inconsistencies.
Just another line item in the check list...
\BEST\LOU
Offline Allan Perret
  • Proverbs
« Reply #5 on: June 28, 2012, 04:48:00 AM »
Good Stuff.   Thanks Randy and others.
Already printed out and going on my flying clipboard.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #6 on: June 28, 2012, 08:30:46 AM »
9. And don't set the valves too tight on the Saito. :)
« Reply #7 on: December 25, 2012, 10:58:48 AM »
If I were to make a set of venturis for a Brodak 40 how close in size should they be and how many would be useful?
Same with head shims, should I just use factory gaskets or thin shims for finer adjustment.
10 thou for restrictor types and 3 thou for true venturies
Offline Andrew Tinsley
« Reply #8 on: March 29, 2014, 01:51:32 PM »
Hello Randy,
I note that your sage advice is for a 4-2-4 break, bearing in mind that a lot of people use say a 2-2-2 set up, is there anything different that you need to consider?
Andrew.
BMFA Number 64862
« Reply #9 on: April 01, 2014, 02:10:49 PM »
Hello Randy,
Andrew.
"These are just ***** basic ******suggestion to help you tune your engine, and by no means covers it all. There are literally thousands of engine setups that would take volumes to cover, But I hope you can use this as a basic guide to helping get a better engine run."
Maybe you should read the whole article. Even a 2-2 is a cycling run, so I made no blunders here
Some people run a 2-2-2 and to do that, normally you just set the engine in a rich 2 cycle, then it will cycle back n forth between a rich and leaner 2 cycle run, this is much simpler, and is the reason most do it that way, some do this to get enough power to fly the airplane well.... Other I have seen run a 2-2-2 in and over lean setup where it sags lean and slow at the top of things... some even feel that is a great run.. I would recommend staying away from the later.
Offline kiwibrit
Re: More Engine setup tips or 9 steps...
« Reply #10 on: January 19, 2019, 02:01:19 AM »
Question: Just seen this.  What is the effect of NOT reducing the nitro content?
Context: I am had problems yesterday with my side mounded engine (set at wet two stroke) cutting out  sometimes on outside loops. Sounds like fuel starvation. The temperature  was cold (about 2°C [36°F]).   I note the advice above to use a lower nitro content in cold weather. I was using my standard 10% brew which worked well in our warm (by our standards) summer last year, and am wondering if the problem could be related to the nitro content.
[Edit:  Have thought about this.  Just wondering if a change of plug would be beneficial for the cold weather.  Currently using an OS#F.  Will try Enya #F]
« Last Edit: January 19, 2019, 10:37:34 AM by kiwibrit »
« Reply #11 on: January 26, 2019, 11:48:59 AM »
Cold weather needs less nitro, when using high nitro you need to run the engine richer.. this can make for flameouts, or stumbling , when you run lower nitro, you need to make the engine run leaner , this puts a little more heat in the motor, similar to running 10% in warmer weather. You will most always benefit using a HOT plug and the correct nitro amount in cold weather.
Other tips are to keep your fuel warm before using it in cold weather, keep your battery warm, I keep mine in my pocket while flying in cold weather.
Use a bit of lighter fluid to help start engines in cold weather
Use fresh HOT glow plug, and fresh fuel
