  • July 11, 2025, 01:19:04 PM
Author Topic: WEBRA speed 61  (Read 2131 times)
Offline bob whitney
WEBRA speed 61
« on: January 12, 2018, 10:30:07 PM »
has anyone had any experience with the WEBRA speed 61 for stunt
rad racer
Re: WEBRA speed 61
« Reply #1 on: January 12, 2018, 10:39:54 PM »
No , but theyre almost a HP 40 , if youre after noseweight .
I believe a few ( Maikus amougst others ) have used Speed 40s .
Ive looked at the Speed 60 RV , and think it should be suitable .
The HP 40 ' they ' drop the Timing to 130 / 110 . Stock I think some of the 60s are that , or 140/120 . a ' spacer ' as piston stop ,
to find 130 Ex , and thats the ' drop ' you need to machine in the case top for the liner . First Checking the piston skirt wont ' unport ' at TDC . Like a FSR 40 does  :-X
just looking at the scetre flight reviews , most are 142/ 120 , but some later are 150 Ex, There were / are some ABC too . Id think 150 Ex may be a little high , 4 in pitch prop like.
so would pay to throw a protractor on and see . Did I mention theyre not light . V similar to the HP 40 , which are V good at 130 Ex , both F & R induction . the RV may be better .
Er , the RV 40 with the 130 timing is still a 4 in pitch prop sucker , for the wind . Tho I believe over there 12 & 11 x 6s were used on em , Bob Mc Donald etc etc . Just hold on, Tight .
Dunno how old this is , was just looking for a picture .
Seems theres some trash for sale, sometime . Sprekinsiedeutshe .https://antiquemodelenginesrunning.blogspot.com.au/2014/07/webra-speed-61-rv.html
Offline GERALD WIMMER
    • Auckland Free Flight Club
Re: WEBRA speed 61
« Reply #2 on: January 13, 2018, 04:09:58 AM »
Hello
A HP 61 Gold Cup (I used rear induction) is very similar and was a motor I enjoyed using for stunt over 20 years ago . Only problem was the rear induction limits tank size and position but front induction would be easier here. Had a nice run and would spin a 13x6 happily but then swapped to a 90 four stroke with 14x6 prop as that was the new thing to try. Those Webra Speed engines still look really nice too !  ;)
Regards Gerald
