  • June 20, 2025, 02:35:27 PM
Author Topic: Webra 32  (Read 1306 times)
Offline Bob Hudak
Webra 32
« on: January 09, 2007, 04:22:35 PM »
I have a Webra 32 that I plan on installing in a Smoothie ARF. I need to know the right fuel to feed it.I'm thinking PowerMaster 10/22.Would this be OK?
350838
Offline peabody
Re: Webra 32
« Reply #1 on: January 09, 2007, 05:09:53 PM »
Yup....that will work.....I have seen stock Webras liking a 10X3 APC
Re: Webra 32
« Reply #2 on: January 10, 2007, 12:13:06 AM »
Either 5% or 10% nitro and 20%-22% oil.  Mine likes Sig 5% - 22% 1/2 and 1/2.
Expect the Webra in stock trim to want to run fast, and I do not believe it will 4-2 with the stock set up.  I have a Webra 28 (the same one Bob Hunt had at first in his published Tucker Special) and a 32.  Both had had a *little* change to the timing, and a hemi job done to the head.
The Smoothie is relatively small, and the Webra will need a very low pitch prop to keep the lap times down.  The Webra is pretty strong, and that combo will not load it much at all.
Bill <><
Offline Bob Hudak
Re: Webra 32
« Reply #3 on: January 10, 2007, 07:12:48 PM »
The Webra has been set up for C/L Stunt.I know it had the timing changed but it looks like it has a stock head. I'll experiment with a couple different props to see what it likes. I'' start with a 10/4 then if its too fast I'll drop to a 10/3. I may even see if an 11/4 does magic to it.
350838
