[quote
Less than .010, and you start getting either the schneurle effects (faster/hard lean on outsides) again or uneven running..
[/quote]
That's quite an interesting find, Brett, and it makes the big picture in my mind more confusing.
I mean, that this thing you call "Schnürle effect" can be affected so far from the actual scavenging.
The only explanation I can think off is that fuel/air mixture with non-homogenic atomization is ignited by plug in clearly less efficient way than a healthy mixture, as if plug were colder.
It would be interesting to see what the effect of atomization is in side-mounted engine or clockwise running engine. Or is it a thing typical for front intake engines?
in your case the Schnürle effect does what it does only when engine is mounted as you have it, cylinder down. But you know, the effect is reversed with side-mounted engines, and I can reverse it once more by changing the running direction.
Because of all that, I have ended up with engine mounted cylinder 45 degrees down for best symmetry.
It's a quite complex interaction and you just made it more complex. Thanks
L
Btw, Lost Hills in October 7.-8. Free flight..
