  • August 02, 2025, 05:30:39 AM
Author Topic: Webra .20/.28  (Read 1074 times)
Webra .20/.28
« on: February 20, 2014, 12:45:53 PM »
Hi All,
I have an unmarked Webra .20 or .28.  I would like to find out which one it is.  Aaron, and I, have ran the .28 in the past but I do not know which engine this is.  I do not have an inside mic.
Offline BillLee
Re: Webra .20/.28
« Reply #1 on: February 20, 2014, 03:45:03 PM »
Bill, a dial caliper will be sufficiently accurate. The bore of a .28 is .728" You could probably measure with a steel rule and be close enough since a .20 will be quite a bit smaller.
Bill Lee
AMA 20018
Re: Webra .20/.28
« Reply #2 on: February 20, 2014, 04:27:47 PM »
Thanks, Bill.  So the .28 is .003 larger than .725  which is basically 5/8ths" IIRC.  Sounds good.
Thanks, again!
Re: Webra .20/.28
« Reply #3 on: February 22, 2014, 06:26:06 PM »
Thanks, again!
No, .625" is 5/8"! So, .725" is 5/8" + .100". Just a bit over 23/32", actually.  ;D Steve
Re: Webra .20/.28
« Reply #4 on: March 04, 2014, 12:22:29 PM »
Mea culpa, Brother Steve, not sure of what I was thinking!  .725 is just shy of 3/4" (.750)!
Thanks!
BIG Bear
RNMM/AMM
