The Delong .30 would be my choice from Skip's list, assuming it's in good condition. I used to own one, but never ran it. I've read good things about Bunch engines also. Forsters were a good quality engine. I recognize a lot of the brand names on Skip's list, but can't recall details most. O&R's run, but I've never been impressed with their power, long life, or engineering. I'm mystified by the McCoy .48...they had a .29, .49, .55, and .60, but never heard of a .48. I'd assume it'd be a scaled down version of the .60 redhead racing engine. Perhaps it's just the number isn't terribly legible. Not sure how easy it would be to make a racing engine like the McCoy's run in a stunt model.
Lots of OTS guys run low nitro/high castor glow fuel in their spark engines. A lot also mix their own with Coleman fuel as the base, with some sort of oils from the Go-Kart store...maybe Benoil and some petroleum oil? I know that OTS requires genuine OEM spark ignition engines OR approved "authentic" replicas. It's NOT legal to convert glow engines to spark ignition...which is legal in OT FF, by the way. Some glow engines are relatively easy to convert and run fine on spark. If you're "handy" and want to tinker, that might be something you'd like to try? No, Motorman, that Evo would not be legal for OTS, unless they've changed the rules recently.
I recall cranking a Super Cyclone .60 for the late Don Dodd, MANY years ago. The main bearing was worn, resulting in the timing changing itself. But I mostly recall getting my fingers whacked violently. There were not enough words....it friggin' hurt that much!
