Engine basics => Engine set up tips => Topic started by: frank mccune on October 29, 2020, 05:08:22 PM
Title: WANTED prop drive key for K&B/VECO .19 engine.
Post by: frank mccune on October 29, 2020, 05:08:22 PM
          If you know of a source of one of gems, kindly contact me.
          Frank McCune
Title: Re: WANTED prop drive key for K&B/VECO .19 engine.
Post by: Dane Martin on October 29, 2020, 06:21:33 PM
Forgive me if I'm incorrect... but are you looking for the prop drive and collet?
Post by: Dane Martin on October 29, 2020, 09:30:53 PM
Is there other versions that uses an actual key? I just pulled that off a veco 19 that I need to repair. But I have several veco and torp 19's.
Post by: Mike Greb on October 29, 2020, 09:57:14 PM
I think the key is just 1/16 square keyway stock,  I have one of those old Veco 19's that has that type of key, and I immediately lost mine when I inspected the motor. Mcmaster carr has  1/16 keyway stock that should work ok.   I ordered some stock but I have not gotten around to cutting a key out of it.
Post by: frank mccune on October 30, 2020, 08:24:16 AM
     Hello:
     Thanks for all of the replies!
     Yes, it is a square key that measures 1/16”- 1/4”.
      If someone would be kind enough to whack two off for me, I would be in Hog Heaven!  The reason that I am requesting two is, one for the engine and one for the floor. Lol. If not, hello MC.
       Be well my friends,
       Frank
