  • July 11, 2025, 07:25:36 AM
Author Topic: Waiting on a red Nobler  (Read 2986 times)
« on: November 11, 2016, 02:28:18 PM »
Waiting on a little red Nobler....
Re: Waiting on a red Nobler
« Reply #1 on: November 11, 2016, 02:32:29 PM »
Not just another Fox .35.  I was fortunate to obtain one of Bob Gieske's own engines that surely put in a bunch of patterns in a red Nobler.  Today I put it on the stand and it fired up in a couple flips and sounded great.  I have a Gieske Nobler kit and soon this engine will be grunting through the pattern again.
« Reply #2 on: November 11, 2016, 02:34:36 PM »
I'm not sure it's exact vintage but it has the tumble polish case which should date it.
Online Motorman
« Reply #3 on: November 11, 2016, 07:37:16 PM »
I like those modern PA needle valve assemblies Randy Smith sells for the Fox 35. Might make a nice engine even better.
« Reply #4 on: November 11, 2016, 09:03:21 PM »
I'm sure they could be an improvement.  Because of its historic/nostalgic nature this one though will stay intact as Bob used it.  It feels pretty good but if I think it's over the hill I may drop a newer sleeve and piston in but we'll see.  I have other engines and might just let this one be a shelf jewel if need be.
Offline Mike Bufkin
« Reply #5 on: November 12, 2016, 04:17:19 AM »
Thats cool,
Did you get it on ebay ?
The reason I ask is because I bought an old 2 bolt sand cast 35 probably from the same seller.
Mine also belonged to Bob Gieseke.
« Reply #6 on: November 12, 2016, 05:14:03 AM »
Yes a family friend was selling his stuff.  I knew for sure it was his because of wood screw mounting marks on the lugs.  Bob mounted these early on- maybe always with wood screws rather than machine screws.
« Reply #7 on: November 12, 2016, 10:59:03 AM »
   If you have a good combination of needle and spraybar,  the stock units work fine.
Offline Mike Bufkin
« Reply #8 on: November 13, 2016, 04:16:14 AM »
And,a short piece of fuel line between the needle and spraybar eliminates that possible air leak.
I've never had a problem with the stock set up.
Offline Allan Perret
  • Proverbs
« Reply #9 on: November 15, 2016, 08:40:09 AM »
Do you know, back in the day was Bob G. using a muffler ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #10 on: November 15, 2016, 09:04:07 AM »
No.  I don't believe a muffler was ever used on any of Bob's Fox Noblers.  He flew them a few years into the .46 era.  When he went larger the mufflers were used.  I last remember seeing Bob fly the Fox the year Jim Casales first won with  the Tigre .60.  I can tell you first hand that Jim's Tigre WITH muffler was noticeably louder than Bob's Fox without!
« Reply #11 on: November 15, 2016, 09:50:36 AM »
   As long as you run it on 5% it's not the end of the world as far as noise goes. 15% *greatly* increases the sharpness of the noise along with a copious increase in power.
     I never ran my Fox with a muffler but I don't know if I could manage it any more!
