  • July 23, 2025, 10:42:00 PM
Author Topic: VP Racing M1 Methanol  (Read 16622 times)
Online Peter in Fairfax, VA
« on: June 19, 2024, 09:18:03 PM »
Is VP Racing M1 Methanol good?  About the only source I've seen in the DMV area.
Offline Reptoid
Re: VP Racing M1 Methanol
« Reply #1 on: June 19, 2024, 10:00:28 PM »
     It's as good as it gets. Stick with M1; M3 and M5 have power adders in them that you don't want/need for our use.
     If you have a speed shop in your area that carries it in bulk to serve the racing community, you can save some money by bringing your own container so you're not paying for a new 5 gallon can with every purchase.
       Don
       AMA # 3882
« Reply #2 on: June 20, 2024, 01:14:36 AM »
Agreed--M1 works good. And a "VP gas station" is the only place somewhat near me that carries methanol. If you buy their "pail" be sure to get a spout that fits it.
Online Motorman
« Reply #3 on: June 20, 2024, 06:40:25 PM »
VP Racing M1 Methanol is the only thing I use in airplanes and the Kart. The Best!
I drive over to Deleware and pick up a 5 gal can. They also sell 1/2 & 1/2 Methanol Nitro if you can't find 100% nitro. You have to calculate on how to mix it though.
MM 8)
« Reply #4 on: June 25, 2024, 03:43:51 PM »
How about Sunoco Methanol?
« Reply #5 on: June 26, 2024, 09:28:21 AM »
   If the local racing crowd shops there, it should be OK. SUNOCO has been supplying racing products for many years.  I was going to ask if there were any local dirt tracks that had regular sprint car, midgets, or any other class of cars that allowed methanol for fuel. That is usually a good grade and often much cheaper. I found a local farm and home oil supply place that sells VP products and also methanol and that's where I got my stuff. See if there is something similar in your area. Even if you have to drive a ways to pick it up, it's still worth it because you only need to do that a few times a year. I still had some SIG 10% nitro, 20% oil Champion fuel left, so I mixed up some new fuel using the new ingredients to that mixture. next trip to the flying field, I put up a couple flights getting tach readings and lap times. Then I just switched fuel and did not have to touch the needle. VP sells several different blends 0fr methanol, and from what I have seen and read, the M1 is just s straight methanol with no additives. Any aircraft or racing grade of methanol should be just as good. Try a gallon on it and test it out. We don't have many SUNOCO stations in these parts any more. Their old SUNOCO 260 premium gasoline was pretty popular with the hotrod crowd.
Offline Perry Rose
« Reply #6 on: July 17, 2024, 07:11:56 AM »
In the town of Watson, Louisiana there is a hardware store called Watson Hardware that races circle track cars and they sell methanol for $3.75 a gallon in 5 gallons only your container or buy one from them. I don't know what brand it is but I've been using it for about 15 years with no problems. Just like gasoline the methanol probably comes from one or two producers/refineries.
  I just found an old receipt from May 2018 and the price was $2.19 a gallon.
« Last Edit: July 17, 2024, 08:00:45 AM by Perry Rose »
« Reply #7 on: July 17, 2024, 08:40:16 AM »
I've mentioned this before.   Methanol is used pretty widely as a cleaning solvent by window washers and others.  Today I am going to pick up a supply from a small local repackaging company that buys larger drums then puts it into smaller containers per order and resells other business.  They obviously handle a wide variety of products the same way.  I've been using it from them three years now and it has always been great.  I buy 15 or twenty gallons at a time in five gallon pails.  I then break it down into gallons as needed.   I would agree most of it comes from a very few suppliers regardless of what name is on it and to my thought is all of good quality as long as it has not gained moisture.  I'd bet you could find local suppliers all around if you thought in terms of it's other uses and not just racing fuels- probably cheaper too.  I've not seen the bill yet but I think I pay around 9-10 buck a gallon from them.   I'm not complaining about that.  It's still the cheapest ingredient in the fuel.  I am mixing fuel for around $20 a gallon.   I can live with that,  and I can mix any formula I wish in any quantity.
I was just checking;   Methanol is used in waste water treatment plants,   making pharmaceuticals,   making inks, paints and dyes as well as cleaning.
« Last Edit: July 17, 2024, 04:08:54 PM by Dave_Trible »
« Reply #8 on: July 18, 2024, 07:58:47 AM »
     If you have ever used HEET! Gas Line Antifreeze in your car, it is 100% methanol, I do believe. Not much real need for it these days with the alcohol in gasoline to start with. Gary Frost would make trips to the Philippines to visit his wife's family and took some old combat models to leave there and for fuel, he could take oil on a f light with him, but taking ready to use fuel was an issue. So he tried using HEET! to mix small amounts of fuel and it worked well. I can't remember if he was able to source nitro there but he could probably fun fly just fine without it.
    I found the VP 50/50 Nitro/Methanol mix at a local home oil heating company that also sold other farm supplies and such, and they had methanol in the $4 a gallon range when I bought it earlier this year. Most other "performance shops" closer to me want $8 a gallon. Next time I need some I'll keep these other sources in mind.
« Reply #9 on: July 18, 2024, 01:49:28 PM »
I picked up my load and (not really complaining) the cost for 15 gallons figured at $13.46 per gal.  This was a fresh drum just received by them Monday.  Like most everything the cost is higher these days-  likely driven more by shipping costs.  I’m OK with it.  Glad to have a good source 20 minutes away.
I have been getting nitro from Hyperfuels.  They seem to be out.  They also only advertise 5 gallon quantities or drums and not gallons as in the past.  I was able order a gallon direct from Torco.   Cost a plenty but free shipping and my supply was cutting it close for the Nats.  I should have enough stuff for fuel for the rest of the season.  Got a stash of VP for emergencies.
« Last Edit: July 18, 2024, 02:09:39 PM by Dave_Trible »
« Reply #10 on: July 18, 2024, 08:11:51 PM »
I paid $12 / gallon for Sunoco at a speed shop an hour from me.  The dealer did not require my used 5 gallon pail.
« Reply #11 on: July 30, 2024, 02:24:22 PM »
Thanks for the comments on methanol sources and quality.  The Sunoco methanol worked out just fine.
