Hi Guys,
Today I set up the new OS 40 FSR. Used the same set up as the old one. The venturie is from a OS 46 SF, needle valve Super tigre. Prop ABC 11/4, fuel 5% with 22% oil, half castor half syn. The baby settled in at 8900 rpm's, which is low compared to my other FSR's. Sounded almost like it was running a 4-2-4 mode. With the test stand I have can't use a muffler or pipe so she's really nice and loud. Yes when I turned the nose up she went right to 12000 but came back to the 8900 so I was happy about that. At 8900 not much vibration at 12000 she had more vibration than my older FSR?? Checked the prop again and its very very close?? Most my FSR I launch at 10200 and they unload in the air. I use the FSR's on pipe. The FSR is a very dangerous engine cause of the amount of power she puts out. I use to start them by hand but I don't do that anymore, I use a starter. Most won't use a starter cause they're afraid that they will push the crank againt the back plate. I don't believe that is true, cause if the thrust washer is correct and the prop is tight, I don't believe you will push the crank against the back plate, just my opinion. Maybe the vibration is harmonic??? I appreciate your input.
Gary
