  • June 14, 2025, 11:53:19 AM
Author Topic: Very Flexable fuel tubing  (Read 860 times)
Offline John Craig
« on: December 09, 2013, 07:42:54 AM »
I am looking for a very flexable tubing for uniflow in 4 oz plastic R/C tank.  I  want  something more flexable than today's average fuel line, even more flexable than the classic Prather fuel line (Yes, I understand there are two types of plastic tanks; the ones that are leaking & the ones that will leak)  The plastic tanks many years ago came with a VERY  flexable tubing that had to be changed at least yearly.  The clunk moved around very freely.  I am willing to change the tubing if needed.
« Last Edit: December 09, 2013, 08:08:22 AM by John Craig »
Offline Bootlegger
Re: Very Flexable fuel tubing
« Reply #1 on: December 09, 2013, 09:41:49 AM »
  You might check with Sullivan Products, I think that their fuel tubing is flexable.
  Good luck, and keep us posted...
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #2 on: December 09, 2013, 08:53:36 PM »
The old clunk tanks used surgical tubing which is very flexible, but as you say needed to be replaced about once a year or so. I have not seen it advertised for years though.
