  • June 25, 2025, 10:48:29 AM
Author Topic: veco 45  (Read 1002 times)
Offline John KruziK
veco 45
« on: January 06, 2011, 08:06:32 PM »
Are all veco 45s ball bearing? The engine seems to be in good shape but has bad roller bearing. Where can I get a replacement and is it worth fixing?
AMA 874027
Offline Andrew Tinsley
Re: veco 45
« Reply #1 on: January 07, 2011, 07:31:51 AM »
Boca Bearings seem to have most aircraft engine ballraces, certainly worth looking there first. As to the Veco 45 being any good for stunt, I really don't know. The Veco 35 and 61 have their followers, so I suppose it likely that the 45 would work. Probably a weight problem?
Andrew
BMFA Number 64862
Re: veco 45
« Reply #2 on: January 07, 2011, 07:44:17 AM »
i john,
All the Veco .45's I ever knew about are BB.  Bearings are available.  As far as the engine being used for stunt, Bob Palmer used them in his "Skyscraper", Bob Gialdini used one in his "Eclipse", and IIRC, Lew McFarland switched from the K&B .45 to the Veco .45 in his famous "Shark".  There were others who used the Veco .45 during the transition from .35 size to "bigger" planes in the mid '60's.  Billy Werwage talks about them in regards to when he was using the K&B .45, but felt they were too heavy.  Weight was a concern but can be worked around for most of us, no problem.
The Veco .50 is the same case, etc., except it uses a Dykes ring.
Big Bear
Re: veco 45
« Reply #3 on: January 07, 2011, 09:27:42 AM »
Hi John
If yours has roller bearings, and they really are "roller bearings" then it is obvious that not all came with Ball bearing. Got any pictures of yours?
Re: veco 45
« Reply #4 on: January 07, 2011, 10:46:23 AM »
Hi John
Or some one found roller bearing that would fit and replaced the ball bearings with them........... or........... "obviously". ;D
