  • June 21, 2025, 12:31:50 AM
Author Topic: Venturi Size Confusion?  (Read 1246 times)
Offline Joe Messinger
« on: March 14, 2007, 09:36:45 PM »
Hello,
O.K.- OS .40 LA engine. Factory venturi measures .283.  Most engine guys recommend .260-.270.
I've converted the remote NVAs on the LAs  to through the venturi S.T NVAs.  The S.T. spray bar is .020 larger in diameter than the OS (through the venturi) spray bar.  Should I bore out the .283 (stock) .020 to compensate or leave it alone?  Leaving it alone equates to .263, I think. . .
Joe
Joe Messinger
Offline rob biddle
Re: Venturi Size Confusion?
« Reply #1 on: March 15, 2007, 04:18:21 PM »
  Hi Joe,
 I'm certainly no expert but for my LA .46 I ordered a factory (unmodified)  O.S venturi and a S.T nva from Tom Dixon.
 Not certain what the venturi size is but it runs great, even without boring the venturi out to compensate for the thicker spraybar.
 In your situation I would run it with the stock venturi first and see how it goes, you can always bore more out later.
 I don't think (without wanting to step on anyones toes) that there is a be all and end all venturi size for any particular engine, if it is in the "ball park" it should work ok.
 Depends on what style of run you are chasing.
 The optimum size can vary in regards to fuel composition, prop type and load, tank style and placement, muffler type and restriction, desired run style, weather, altitude, amount of power needed, etc etc etc.
 So I would start with it stock as a benchmark and work from there.
 The other option is if you have seen an LA .40 that runs the way you want, copy that set up to the letter!
 Cheers, Rob.
Robert Biddle
« Reply #2 on: March 15, 2007, 10:17:53 PM »
Rob,
Thanks for your reply.  That's good advice.
I doubt that subtle changes would make much of a difference for me anyway.  My planes are sport models and my flying skills aren't that great.  I did fly an LA .40 that I refitted with a Super Tigre NVA and didn't change (open up) the stock venturi.  I had to turn the needle out a bit more but it seemed to perform well.  Just wondered if anyone else had some input.
Best regards,
Joe
Joe Messinger
« Reply #3 on: March 28, 2007, 05:31:58 PM »
When you are trying to set the venturi size, run the engine up to peak rpm on the prop of choice.  That sets a bench mark for how fast it can run.  Then when you try different size venturis(effectively changing the throttle opening) you can tach those at peak rpm and know exactly where you stand relative to the original.  A lot of times you will have to change both the venturi and the prop to get the motor in a happy spot.
Offline Tom Perry
« Reply #4 on: March 28, 2007, 06:24:06 PM »
How the engine is muffled may have as much to do with the run as prop and or venturi.  H^^
Tight lines,
Tom Perry
 Norfolk, Virginia
« Reply #5 on: March 29, 2007, 08:51:14 PM »
The .283 venturi with an ST needle valve through it is a decent place to start.  With the OS needle valve it may be a tad large.  A lot of folks use .283 on the 46 with the OS nva.   Depends a lot on the prop, plane, and fuel too. They all have to be adjusted together for best results.
« Reply #6 on: April 01, 2007, 08:21:55 PM »
Another big factor in ventura size is compression ratio. If you add head shims, you can go to a larger ventura. If you reduce head shims, you may need to reduce the ventura size. Both of these items can change fuel mileage quite a bit. If you lower the compression, and reduce the size of the ventura to much, the engine will use very little fuel, and can run hot from lack of oil and fuel going through the engine.
