  • June 30, 2025, 08:58:42 PM
Author Topic: Plastic Clunk Tank Plumbing  (Read 1338 times)
Offline Walter Johnson
« on: February 09, 2007, 04:15:45 PM »
    I will be using a Sullivan 8 oz rectangular plastic tank in my Tempest II. Would like to know the best uniflow plumbing for this. I will be running a PA 51 on pipe.Thanks Walter
Take a spin.....You might like it.
Offline Wayne J. Buran
Re: Plastic Clunk Tank Plumbing
« Reply #1 on: February 10, 2007, 04:17:49 AM »
Walter, check in with Allen Brickhouse, he did an excellent article on plumbing plastic tanks. Thats the referance I always use for my plastic tanks.
Wayne Buran
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
« Reply #2 on: February 10, 2007, 10:08:49 AM »
Hi Walter
Most all using the plastic tanks are using 2 differant types of venting
1 being uniflow with the uniflow vent attached to the fuel pick tube with thin flexible tubing or 2 tubes to the back. one uniflow and 1 pickup
The other venting scheme is for the uniflow vent to curve back from the front of the tank to the front inside top position, not really uniflow but it seems to work well for people. It gets the vent uncovered almost instantly and stopped the  mid flight setp up ( in speed)  that occurrs in a lot of plastic tanks.
