  • July 14, 2025, 10:00:35 PM
Author Topic: Venturi question.  (Read 3897 times)
Offline Lauri Malila
Venturi question.
« on: May 20, 2015, 02:58:44 PM »
Hi.
 After the latest combustion chamber experiments, our .77 stunt engine runs so well that I have started to prepare the next (and hopefully last) version of it. I would like to have the new versions ready for world champs.
Our engine is very energy efficient, it only uses about 2,6oz of fuel / flight.
For me it's not a big problem, but the high efficiency has a price; the engine is slightly more sensitive to variations in atmospheric conditions. As I don't play with nitro, I must be able to change venturi size rather quickly.
I use "true venturi", made as per Randy's instructions, and they work very well indeed. The only addition to Randy's instructions is the use of fuel post(s), my venturi's use 2 posts at 60 degr. spacing. Both posts have a 0,7mm (1/36") hole for fuel flow. The posts extend 0,8mm (1/32") into the venturi bore. Average venturi size is 4,5mm (0,18") and I must be able to go up and down in diameter +/- 0,2mm, in 0,1mm steps.
So far my venturi's are like in the picture, plug-in type where 2 O-rings take care of leaks and keeping them in place.
They work well but sometimes they get stuck and in the end they are not so easy to change.
For the new engines, I've thought about making screw-in type venturi's, with a lenght of fine thread between the venturi shroud and first O-ring. In that case I must naturally have a sprinkler type venturi with several radial holes, and this brings us to my question:
How many holes and of what size?
Cheers, Lauri
Re: Venturi question.
« Reply #1 on: May 20, 2015, 03:12:23 PM »
Why can't you retain the fuel posts?  Just groove the venturi where the fuel posts are fed so the fuel can be brought around to any location (which is what you'd need to do for a sprinkler type, anyway).
Alternately, why not use a very coarse thread, like a jar lid or a bayonet connection?  (If you have any handy, grab a BNC connector -- that's what I'm thinking of).  That way you can get a positive orientation (which may be important with your fuel posts), and a positive ejection of the venturi against the thread.  Some sort of flats on the thing so you can get on it with a wrench may be helpful in the event that O-rings get stuck or whatnot.
Offline Bill Johnson
« Reply #2 on: May 20, 2015, 03:55:28 PM »
Do you use any lubricant on the O-rings? Petrolatum is a common lube used on aircraft fuel system O-rings. It might ease installation and removal.
Best Regards,
AMA 350715
« Reply #3 on: May 20, 2015, 04:05:45 PM »
Good ideas Tim, thanks.
Well, at the moment I can twist the venturi's +/-30 degrees, it had no effect on running symmetry issue but it is quite a handy way when fine-tuning inverted and level lap times.
Maybe I missed something but the post position would not be very predictable with a threaded venturi insert.
Also, my venturis are quite complicated to make, fuel posts are very small.
For that reason I think that a sprinkler a'la Super Tigre would be more practical.
I am well aware of the problems of ST unit (peripheral groove size, leaks, bad workmanship..) but those issues can be fixed.
The function of thread is of course to lock the thing in place, but more importantly to assist in pulling it out. So the thread pitch has no importance. I have something like 10x0,7mm thread in mind.
Oh, and I will be using a remote needle valve. It should make things easier and it's also better for engine operation.
L
« Reply #4 on: May 20, 2015, 04:07:14 PM »
Bill,
The 20% oil in fuel keeps things slippery.
« Reply #5 on: May 20, 2015, 04:31:02 PM »
Hey Laurie:
If the threads are coarse enough and end positively enough you can both control rotation and have clamping action.
Here's the BNC connector I was talking about: https://en.wikipedia.org/wiki/BNC_connector.  These go on and come off with exactly 1/2 turn, so you could make things land right where you wanted.
Of course, if a sprinkler type works well enough there's no need to mess around with it.
« Reply #6 on: May 20, 2015, 04:49:51 PM »
Tim,
The only control of rotation I need is to be sure that the position is every time the same. Being able to change the post direction was just one attempt to understand the issues I had with running symmetry. It's no longer necessary.
The BNC type bayonet is for sure worth thinking but at the moment I think the fine-ish thread is the best way.
But back to the original question. My biggest worries about the ST type radial holes/peripheral groove is how easily it gets blocked by dirt and how quickly the engine stops after I actuate the shut-off device. I think I'll make such a venturi to my current engine to find out. L
Offline Chris Wilson
« Reply #7 on: May 20, 2015, 07:32:39 PM »
Hi Laurie,
             can't help but think that a good solution to your want to readily change the throat size would be to use a permanent 'master' venturi and use a changeable insert opposite the twin posts.
Much like the 4 stroke boys do with a nylon bolt, perhaps you could come up with a better engineered solution than that.
After all you only need to change the internal diameter with your original and not the whole fitting.
Thoughts?
« Last Edit: May 20, 2015, 08:06:08 PM by Chris Wilson »
MAAA AUS 73427
« Reply #8 on: May 20, 2015, 08:51:04 PM »
Hi Lauri  many years ago I made all types of sprinklers, and modified ST venturies, you know some of the downfalls of the ST, the burping, the tiny holes stopping up, bursting lean/rich, etc.. We made a piece that blocked off all but 2 of the holes, then opened the holes diameter up. This works much better with only 2 holes, I tried it with almost all number of holes, 1 or 2 is best. You can make a cylinder to slide the ventuire in and use JB Weld to block off as many as you want to try, or make a 3/4 circle that will block off holes.
I used the red silicone O-Rings top/bottom to seal, they take a set and stay, but a slight twist will pop the orings loose for removal.
« Reply #9 on: May 20, 2015, 10:39:07 PM »
Randy's experience was about like mine, and mine ran somewhat better with only one hole open (although I had no real issue with all 6, as long as I ran muffler pressure). I think the issue was the same as some RC guys suggested to me about the Tee Dee 049- that without pressure, fuel would feed from one or two of the holes, and air would be drawn in through through the others into the annular manifold.
    I think you will do better making sure you can always put the hole or spigot/fuel post in the same place, that is, always at the rear or the front. Which hole you leave open on the ST seemed to make some difference as well. In particular, it's clearly sensitive to the direction of the relative wind running across the inlet and I expect that its different if the fuel outlet is in the rear or not. As always, you should run some sort of diffuser to prevent laminar flow and hopefully minimize the effect.
     I also note Chris Wilson's suggestion about the Berringer-style venturi. I haven't tried it but it appears to solve the problem of being able to easily vary the choke area and also doesn't have the problems you get with flush fuel outlets.
« Reply #10 on: May 20, 2015, 11:30:23 PM »
Thanks for taking note of that Brett, in hindsight I was wondering if plastically deforming the venturi side with an external adjustment bolt would be possible rather than having the bolt intrude internally might work? (The mount of tuning and therefore distance of deformation needed should be small enough surely.)
A thin walled Delrin section around the bolt maybe able to cope with it and perhaps give a better and cleaner section.
MAAA AUS 73427
« Reply #11 on: May 21, 2015, 01:12:33 AM »
  Maybe even just a short bit of polyethylene tubing with a clamp around it to squeeze it to size. Still I would try the Berringer setup first and see if there is anything funny about it that needed fixing.
« Reply #12 on: May 21, 2015, 10:14:08 AM »
 ...polyethylene tubing...clamp...to squeeze it to size.
That sounds like a solution that would work perfectly in perfect world or computer screen, but I'm a little cynical of its user-friendliness in reality.
Actually, the thing is that I like systems I can duplicate 100% after full dismantling, I hope you understand what I'm after. A flexible venturi is not  so such.
But, I dug an old proto backplate from junk box, and it may be worth further development.
It has a simple restrictor/plenum chamber/fixed fuel post, just like in team race engines.
I think I can duplicate that geometry to my current engine, as well as the ST style sprinkler, go testing and see if I find any differences from my std setup.
L
Offline Al Ferraro
« Reply #13 on: May 22, 2015, 06:17:51 AM »
             Here's some photos of the restrectors the RC car guys use in their carb to adjust the power curve without removing the carb.
Al
https://images.search.yahoo.com/search/images;_ylt=A0LEVyQuHV9VW9IAHsZXNyoA;_ylu=X3oDMTEybzN0Z3VlBGNvbG8DYmYxBHBvcwMxBHZ0aWQDQjAxNDVfMQRzZWMDc2M-?p=Rc+Car+Carburetor+Restrictors&fr=yo-yhp-ch
« Reply #14 on: May 25, 2015, 02:58:19 AM »
L
So when you change the internal diameter of the venturi you change the distance of your fuel posts jets half of that distance from the side walls as a consequence?
That and it looks like that if you go for the old type of screw in insert you will have quite a step after the threads stop.
Would be feasible to stick with your current twin post set up, use a straight tube to mount them in as a fixed carrier and use a range of inserts that are off centre bored in such a way as to keep to the jets or the posts exits in the same relative place every time?
In other words changing the ID of the venturi will introduce a secondary change of moving the jets position relative to the center of the air flow (because they are not centred upon it in the first place) and could get into a boundary layer problem.
I envisage your inserts to be bored so that the jets end up the same distance from the side walls regardless of  insert diameter, hence the off set on any insert bar the master and having two slots cut into them from the bottom to allow fitment around the jets once slid in place.
This way could minimise the changes to purely throat diameter and be easier to make conclusions with.
Cheers.
MAAA AUS 73427
« Reply #15 on: May 25, 2015, 10:09:35 AM »
Chris,
Yes that would be the case with the T/R style plenum chamber & fixed fuel post. With my current venturi's , the posts allways stick 0,8mm (or 1mm, I don't remember..) in the bore. So, I must make all the spigots individually for each venturi size.
But honestly, it's not so critical and I shouldn't waste my life in such nonsense.
I have noticed that after 0,6mm the spigot lenght makes no noticeable difference, so I guess the boundary layer effect you mentioned is somewhere before that, maybe at 0,5mm.
Without the fuel post, with just a 0,6..0,7mm hole, I see no difference in running character, just the needle has to be slightly more open, like 1/8 turn or so, for same mixture.
All this can become an issue if the rest of engine is not healthy. Stability comes mainly from good burning efficiency and correct load.
L
L
