  • June 25, 2025, 06:05:40 AM
Author Topic: Venturi  (Read 1001 times)
Venturi
« on: September 17, 2010, 07:42:56 PM »
Well, that was a fun hour.
It's a 7/32" bore, on an OS Max 25 (not FP or FS or any nonsense -- just a cross-flow OS Max).
Things calculated out to needing something a hair bigger than 7/32 -- I'm going to finish this one, then make one with a 15/32" bore, and see what I can see.
Spraybar will be 1/8", or a hair under.  I was kinda surprised -- the carburetor hold-down screws are obviously M3, I expected smaller holes.  Note that I'm not complaining.  I just got a 5-44 tap & die set from McMaster; the thread's probably a bit coarse but I'll find out!  If the needle's too hard to set I'll try scheming on a finer thread (there are M3 x 0.35 tap & die sets out there, but they're spendy) or I'll experiment with less slope on the needle itself.
I fantasize about making a #5-64 tap -- but that's probably best left a fantasy.
We'll see how it works.
Offline Marvin Denny
Re: Venturi
« Reply #1 on: September 18, 2010, 07:24:31 AM »
Uh---------Tim-------uh----  Do you REALLY mean 15/32s???   Or perhaps 15/64ths?  I would think that 15/32nds would be more than just a "tad" larger.
  Bigiron
marvin Denny  AMA  499
Re: Venturi
« Reply #2 on: September 18, 2010, 09:31:12 AM »
Well I'll just open up the crank to match this venturi and -- oops!
Yup -- 15/64ths.  I want a drill index full of number and letter drills for Christmas.
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Venturi
« Reply #3 on: September 18, 2010, 03:32:49 PM »
Back in the 60s, in the combat circle I saw a Johnson with the venturi bored out to paper-thin walls, and crank port opened up to match.  It looked like about 15/32"!  On bladder pressure of course.  I didn't get to see it run, just bite the dickens out of anyone who tried to start it.
--Ray
AMA902472
Re: Venturi
« Reply #4 on: September 18, 2010, 03:53:18 PM »
It's done!  It runs!  (well, at least it got through an ounce of fuel -- more to come).  Now to run some more fuel through, just to make sure.  This is an engine that I bought at a rummage sale in the early 1980's, along with the all-styrofoam RC Cub to which it attached, and ran just once or twice since (mostly long enough to find out that I couldn't readily transition to a transmitter that used one stick for elevator and another for rudder -- the plane had a short life).
The engine just got the whole crock-pot/antifreeze/scrub off the residue treatment, and a brand new venturi, of course.  I'm not all that experienced at engine teardown, but it looks to me like it's probably broken in but not at all worn -- which should be perfect.
And I saved what -- $15? $20?  For only four hours of work!
Re: Venturi
« Reply #5 on: September 18, 2010, 03:53:57 PM »
Hot rodding engines is great fun.  It's even more fun if they actually work when you're done.
