Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 21, 2025, 09:08:15 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Veco pistons
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Veco pistons (Read 781 times)
Russell Shaffer
AMA Member
Trade Count:
0
Admiral
Veco pistons
on:
August 06, 2007, 08:19:27 PM »
I have seen ways to "grow" a Fox, McCoy, etc piston. Can anything be done with an old Veco 45? I don't even know what that piston is made of, but mine could stand a little more compression. Any suggestions will be appreciated. Thanks.
Logged
Russell Shaffer
Klamath Falls, Oregon
Dave Adamisin
Guest
Trade Count:
0
Re: Veco pistons
Reply #1 on:
August 07, 2007, 10:49:00 PM »
Hi Russel. This may seem a little mid-eval but I've had good luck on othe steel pistons using this technique. I take the piston (no pin) and balance it on an aluminum bar. I put about 6oz of 10w30 in a soup can. I then take a torch and heat the piston carefully untill it becomes deep red all over. I then quench it in the oil. It should grow. I have revived quite a few engines this way.
Logged
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Re: Veco pistons
Reply #2 on:
August 08, 2007, 06:27:08 AM »
Hi Dave,
That sounds better than the "oven method".
Logged
Big Bear
AMA 95351 (got one of my old numbers back!
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Veco pistons
