  • July 03, 2025, 08:21:17 AM
Author Topic: Using a short plug in lieu of long plug?  (Read 1722 times)
Offline frank mccune
« on: September 10, 2017, 08:01:56 AM »
     Hello:
     I found a stash of short glow plugs.  What are the negatives if any, to use these for sport flying in engines designed to use long plugs?
        Tia,
        Frank McCune
Online Perry Rose
Re: Using a short plug in lieu of long plug?
« Reply #1 on: September 10, 2017, 09:31:52 AM »
The .46LAS comes with a short plug and runs fine with it.
Offline dennis lipsett
« Reply #2 on: September 10, 2017, 12:33:58 PM »
The la46 uses a medium plug it is shorter than a long plug and longer than a short
« Reply #3 on: September 10, 2017, 01:18:54 PM »
typical thing is  they run cooler  and  not as clean
« Reply #4 on: September 10, 2017, 04:21:14 PM »
A "kid" in our club some years ago had a U-Key 35 with a Fox .35 Stunt and bought a short Fox glowplug for it (as recommended by the knuckleheads at his LHS). It would start, but was very touchy on the NV and barely ran. We screwed in a Thunderbolt R/C Long and it was entirely different and relatively civilized, so flying could commence.
Short glowplugs belong in engines .15 CID and smaller. But I guess if you wanted to (and could do the machining), you could lower the glowplug seat enough to get the business end of the short glowplugs flush or slightly protruding into the combustion chamber. That would make them run properly, unless they happen to be Fox or Fireball glowplugs, of course.  D>K Steve
« Reply #5 on: September 10, 2017, 05:40:28 PM »
I kept Fox and Fireball plugs for all of the cheapskates who were always borrowing something and then having to chase them to get it back. They would put up with crap runs because it was free.
Offline Ron Cribbs
« Reply #6 on: September 10, 2017, 08:56:27 PM »
Compression.
It may not seem like much, but read Mr. Helmicks comments above.
