  • June 20, 2025, 03:56:44 PM
Author Topic: Up right Fox 35 tank installation  (Read 1070 times)
Offline Leester
« on: April 29, 2016, 09:27:32 AM »
I am building a Brodak Thunderbird with a L&J Fox 35. I am going to use a 4oz ATF Brodak tank BH-489. The pick-up tube is 1/16" higher than the NVA pick up (at the center of the tubes) is this going to be ok or do I need adjustments made ??
Leester
ama 830538
Online Jim Kraft
Re: Up right Fox 35 tank installation
« Reply #1 on: April 29, 2016, 09:50:05 AM »
I would put 1/16"s aluminum pads under the motor.
